A clunking noise when backing up...!
Old Apr 28, 2005, 09:16 PM
Rastmp's Avatar
Question A clunking noise when backing up...!
I just bought my evo and to my discust I started hearing a clunking nois when backing up....Does anyone know why this is happening?
Did anyone experience a simillar problem?
Thank you
Old Apr 28, 2005, 09:20 PM
guitardave24's Avatar
there should be some info on this already in the forums... but be more specific? is it only when you press the brakes? where does it sound like its coming from? etc
Old Apr 28, 2005, 09:23 PM
mobounce's Avatar
i have it when i press the brakes too...what is that..its so damn annoying!
Old Apr 28, 2005, 10:11 PM
Rastmp's Avatar
happens when backing up...no breaks.
i looked at other posts and most people have the same issue.
i guess its the way the car is built....
Old Apr 28, 2005, 10:13 PM
DCSilvrEvo's Avatar
Did you get your clutch changed? Mine started to do it after i got the tranny taken out and put back in. It doesnt do it as much now maybe once a week or so... Something loose?
Old Apr 28, 2005, 10:15 PM
dizzigital's Avatar
yeah, it's the big clunker!!! you either have to be in the zone or take it ever so slightly to avoid it. i get THE BIG CLUNKER almost everyday!
Old Apr 28, 2005, 11:57 PM
plokivos's Avatar
me too
Old Apr 29, 2005, 12:21 AM
mobounce's Avatar
WELL.....what is it? i never had any tranny problems, nor do I. I have stock clutch with almost 20k miles, no problems.
It almost feels like my brake pads arent snug in there..and when I press the break, it pushes the pad, then pushes on the rotor..thats what it "feels like"...no problems in any performance with my breaks/tranny though..hmmm. I have project mu pads, but have been running them for almost 8 months.
Old Apr 29, 2005, 01:36 AM
plokivos's Avatar
well, me i have aftermarket clutch. after that, clunking when put in gear and when clutch out.
pos don't bug me...
Old Apr 29, 2005, 04:08 AM
thestaton's Avatar
mine will do it after I let it sit for 7 to 14 days without driving. after I warm her up I'll go to put it in reverse and the car wont budge under just a little idle. i give it a little more gas and bam pop and I'm off. very weird and it worries me!
staton
Old Apr 29, 2005, 04:13 AM
turboex's Avatar
staton
LOL dude let me help you. Thats the rotors just sticking to the pads, due to time and rust. No issue at all. If you wash your car and let it sit for a hour or so you will see them rust. then try back up it will give the same effect. No issues. Also when going from forward to reverse there will be a sort of clunk, its just drive line noise. Its just the slack in the drive train. Like axles, tranny, diff, and stuff like that. Evo hasa huge amount of joints in drive train so noise should be expected. Hope this helps some
Old Apr 29, 2005, 04:24 AM
Former Vendor
Curt@MrLed's Avatar
are you talking about rotor rust clunk or the clunk of the rear diff when you put it in reverse.. either way now you know, both are normal..
Old Apr 29, 2005, 09:36 AM
Clunking when pressing on the brakes after going in reverse is normal. Basically it's almost as if the pad was manufactured a hair off and doesn't fit snugly. I got this on rear Hawk pads. I changed them back to project Mu and it was gone.
Old Apr 30, 2005, 08:45 PM
EvO6-RS2's Avatar
RASTMP...is your EVO brand new?? or second-hand??
If it's a 2nd hand vehicle it could be possible damage in the center diff. Had this problem, when I reversed and locked steering wheel it made a clunking noise. 4 bolts that hold in diff housing where broken.
But this is only if it's 2nd hand...if it's brand new, sorry can't help u.
Jason
Old Apr 30, 2005, 08:51 PM
Cabo's Avatar
This sounds like the noise I get every day when I back up. It sounds like the rear differential engaging. Others on this site report the same thing.
Basically, I put it in reverse, and as soon as I start moving there's a split second where everything "catches" before the car starts moving. I get an "aluminum" sounding "clunk" and the car moves. I've had my EVO for 22,600 miles with no major problems, and I get this sound almost every day.
Cabo
Quick Reply: A clunking noise when backing up...!
