DOG BOX vs STOCK TRANNY
I don`t understand why not to use DOG BOX in DRAG RACING and it`s a lot faster that with TRE or Shepher modded trannys???
If AMS makes 10.2 with TRE TRANNY,it means that with DOG BOX it would make 9sec absolutely EASY!!!!!AL - the same situation
Just imagine- Constant acceleration without releasing throttle all the time!
I think you're confusing a Dog Box with a Syquential Manual Gearbox. Not the same thing....
A "Dog Box" generally refers to a standard gearbox that has been upgraded to straight cut gears that have no syncros. The lack of syncros allows the gears to be wider (stronger) and the gears are usually straight cut as opposed to helical (also stronger but very noisy). The conbination makes a very strong gearbox that will required rev matched shifting in all situations.
A syquential manual gearbox is a transmission that can shift gears on the fly, usually with a ratchet type shifter. These trannies are not necessarily stronger than a standard gearbox, and I don't believe the stock tranny can be reworked into one without some serious modifications.
- Steve
- Steve
ever drive a dogbox? That is reason alone to not get one if you dont need to. If a synchro box holds the power, it's the obvious choice..at least the car remains driveable!
Good thread about dogboxes from nasioc.com
http://forums.nasioc.com/forums/show...6#post10777496
Also look at the video posted in the thread.
Incidentally, current Group N Evos use dogboxes (5-speed).
I wouldn't want one though on anything but a dedicated motorsports car.
The guys from Magnus built a nice dogbox for the 1G and 2Gs and have been driving them on the street. A few guys on the dsmlink board are using them on their daily drivers without much complaint.
http://www.magnusmotorsports.com/transmission.htm
- Steve
- Steve
also the dogbox usually uses straight cut gears not necessarily because the straight gears are stronger but because the straight gears won't cause deflection loads which is usually what hurts things like housings. or if you are not nice to it then it can twist and strip teeth. this isn't a problem with straight cut gears.
a dog sequential gearbox acutally doesn't need to be rev matched in all situations (ok i say this with tongue in cheek cuz if you don't you'll have a really really really bad time). you just need the engine to disconnect from the rest of the powertrain momentarily for it all to work. that's why in rally they get all that popping when they shift (well there's other reasons too) but every shift is a momentary engine turn off and that allows everything to work. of course the revmatching is desireable.
also with sequential shifting, if you have a hydraulic shifter you usually need to develope a special way of shifting, which i guess they're talkin' about in the nasioc thread. it requires a full commitment shift... no half assing, you gotta yank that sucker cuz otherwise it'll cruch a lotta stuff.
Every time we have switched to a dogbox we have been able to knock .5 seconds off our quarter mile time from the shifting, they last longer before tear downs, and are eventually cheaper in the long run. Expand that over how many times you shift in a roadrace car or rally car and you can see why a dog box can be so beneficial to times.
0.5 sec!!!!!!
If AMS ran 10.02
with DOG BOX at least 9.6sec easy!
And it`s NO NOS!
0.5 sec!!!!!!
If AMS ran 10.02
And it`s NO NOS!
