coolant reserve tank question
Old Aug 19, 2005, 09:41 AM
Derek888's Avatar
In the morning when the engine is cold I opened the radiator cap to check to see how much I coolant I have inside, it was full to the top. But my reserve tank is dry empty. Is this normal?
Old Aug 19, 2005, 10:36 AM
bolsen's Avatar
jup
Old Aug 19, 2005, 10:42 AM
Registered User
nubby's Avatar
Checked the manual:
13.Remove the radiator cap after the engine has become cold,
and pour in coolant up to the brim. Reinstall the cap.
CAUTION
Do not overfill the reserve tank.
14.Add coolant to the reserve tank between the "FULL" and
"LOW" mark if necessary.
Sounds like you need to add some coolant/water to your overflow tank to top the system off.
And a warning from Mitsubishi:
CAUTION
Do not use alcohol or methanol anti-freeze or any engine
coolants mixed with alcohol or methanol anti-freeze. The
use of an improper anti-freeze can cause corrosion of the
aluminum components.
Old Aug 19, 2005, 11:02 AM
Derek888's Avatar
thanks
Old Aug 19, 2005, 09:52 PM
Joey B's Avatar
Good info...
evrblazin
Apr 14, 2010 08:44 PM
Johnboy1065
12
Jan 28, 2008 01:38 PM
dino21
Oct 3, 2007 01:59 PM
EVO_GUY
12
Feb 19, 2005 12:44 AM
kiran197
Lancer Engine Tech
Oct 13, 2003 07:51 PM
Quick Reply: coolant reserve tank question
