installed tbe today. no check engine light?
should the check engine light be on after tbe installed? i have the cat-delete on my car and drove home (about 10 miles) but the light didn't go on. i dun mean i want the light on but is it normal?
be careful when using the anti-foulers. i did that originally and it put the end of the o2 sensore so close to the chassis of the car that when i would turn hard or hit bumbs it would hit against the body of the car, causing one of the wires to be exposed and eventually shorting the main engine fuse out. i changed to a different mechanical fix with a 90 elbow. good luck.
Originally Posted by Evoryder
normally comes on when cruising on the highway...when computer does the routine checks...
Originally Posted by rghli
i dun have it on so far, but the anti brake. it almost killed me for twice while i wanted to brake at 90 mph. the ABS kicked in and i almost lost control.
