OIL in the INTAKE??
OIL in the INTAKE??
okay is this where the blow by oil goes to if its not caught in the catch can? Or is this just normal? I dont think oil is supposed to be in the intake tube of the turbo is there? Do you guys think I need a catchcan? Or is this worse? OIl leak?
I'm starting a project in my garage. Project is huge and it involves me not driving for the next 3 months perhaps more possibly and taking the buss :::sigh::::. but theres light at the end of the tunnel. My project will include full intake upgrades from tubing to the throttle body and everything in between, full exghaust system starting with a new tme 6.5 turbo with the 10.5 hotside to the bushur ported and jet coated manifold all the way down to the bushur ss catback with magnaflow( cat will remain ), AEM ECU to top off with MAP sensor and UEGO gauge controller. The drive train will be reinforced with the CUSCO twin plate, works hydraulic lines, dOT 4 ATE SUPER BLUE fluid and WORKS brake lines, Qeef...I mean Quaffe diffs, AND OH SO LOVELY buddy club P1 QF wheels 17x8 with 45mm offset wrapped in TOYO RA-1's..................mmmmmmmmmmmmmmmm I'm gonna love to get back on the road in hahahahahhaha 1/2 a year
I have 32 k on this bad boy and I'm starting this project cuz' I need a new clutch so I'll change everything I take off.......hhmmmmmm wont be needing the old pieces. I guess I'll have to start selling stuff.
its cuz your evo is running pig rich with the stock map.... do you see a tube that comes from the corner of your engine and it goes right into the intake tube.... thats why your getting that oil, and that is where you install the catch can.
as soon as get your fuel map adjusted by yourself or a flash tune, you will much less.
