Tips for QTP Electronic cut-out (Dump)
I have the QTP (Quicktimeperformance) electric dump, with a side pipe. I didn't want the traditional exit at the down-pipe,as a undercarriage fire was a concern to me. Anyway, I am on my 3rd electric motor, and each one costs 30.00. Here is a tip:
1. Open the dump valve via the switch, and it is fully open to closed in 5 seconds. Don't hold it longer, it will burn out the motor! (my failure 1)
2. dont try to open or close it at 50 mph, the exhaust pressure will fight your opening and closing it, which will also burn out the motor! Better off to OPEN or CLOSE it at idle!(my failure #2)
This might help if you decide to get one. Remember, I will break the stuff, and report back on here, how I broke it!!
they will last a long time if you dont abuse them. qtp really needs to find a way to prevent people from holding down the switch too long. either a single touch switch, or an autoshut off. that would prevent nearly 99% of the cutout failures
I love the product, and will get another motor if needed, this thread was started as an INFO thread a "dont do what I did thread", a headsup. my mechanic burned up my firts one, he held it open too long (the switch)
I thought there would be a HP gain, but there was ZERO! I had it on the dyno at Dyno4mance, and there was no gain. Maybe because I had the sidepipe comming out in front of the back wheel (hence a long exhaust #2). A dump at the downpipe would give you gains.
Originally Posted by Ludikraut
Yeah, but in all fairness, you already had a test-pipe to begin with, so no gains can really be expected. However, it does sound badass as hell.
l8r)
l8r)
Nice post. My instructions said not to hold the switch down for long periods of time but didn't say anything about opening it while moving... I'll keep that in mind.
I have a badlandz cut-out, same as quicktime but I think a little less expensive. Anyway its installed after the downpipe on my car (not the EVO) and I'm running a full 3" exhaust. I'll be at the dyno tomorrow night so I'm curious to see if I gain anything with it open or closed.
I learned the hard way, about opening and shutting it while the exhaust pressure is trying to do the opposite to the "flap" of what you are trying to do. I burned out my 2nd motor this way. I gradiated from the skool of hard knocks, just letting you know what I find with the parts I mess up! Thanks for the kind words!
I am off to break something else now, Later!
If you have a well made free flowing 3" cat back system you will see minimum gains from a cutout. I love the QTP downpipe on my wifes WRX mated up to the restrictive stock cat back system. I have a dyno proven 20 wheel HP gain on the dyno between having the cutout open or closed. Car is almost as quiet as stock with the cutout closed, and louder than hell with it open. I only open or close it with the engine at idle or shut off, with 5 seconds max hold time on the switch, never at WOT and it has been on the car for months now with no problems.
Keith
Keith
Good news for quick time performace cutout users!
They have come up with a controler for the cutouts instead of having to use the toggle switch. Here is a video demonstrating it in use:
http://www.quicktimeperformance.com/...Controller.wmv
• Controls up to 2 QTECs
• Calibrates each motor independently and synchronizes their position (open, closed, partial open)
• Automatic close at power up
• Digital status display shows door position
• Manual pushbutton operation for open, close, or partial open
• User configurable partial open position
• Automatically open or close by grounding or not grounding the trigger wire (for use with engine management system)
• Short circuit protection on motor drive electronics
• Fault detection and reporting
Later,
Keith
Later,
Keith
Buttah!
So now, I could hook one of these up and wire it in with my XEDE map switch, so that when I run a racegas map, it would also open the dump pipe. Very nice.
l8r)
l8r)
