Forge RS BOV + Alky @ 25psi
I know there's a few of you running the Forge Rs on alky. I'd like to know where you have yours set at, close to max, in the middle or towards the soft side. I know each car is going to be set up different but just wanted to get a cross section of where you guys have yours set at with alky. I just got done installing mine and am in the process of testing and tuning it for my car.
Originally Posted by Ryu123
I was running alky with the Forge RS. I was unable to set it where it would not surge/flutter driving around town without going WOT. It may have been just me but I ended up replacing it with the APS DV.
I dont know if you have a MBC or not, but my car used to buck when I had it hooked up the the BOV as a souce, but since changing it to use the turbo as a source it doesnt buck at all. I don't have alky, but I thought maybe this would help.
When it surge/futter, does the car just bucks. I haven't experience any bucking yet but one thing that's new to me is when I'm at half thortle and let off, the bov makes a distinctive sound, sounds kind of like a rattle snake in the motor, at WOT it makes the normal BOV sound. Is this normal for this valve? When I have the 1G, I'd only hear the same sound with the BOV venting. After I crushed my 1G, it too was making the snake sound at part throttle.
Yes the "rattle snake" sound is normal or at least I think so cause I was hearing that too with mine.
Originally Posted by hawjdude
All man, you should called me up first before you bought one. I have the Forge RS bov sitting in my room. See ya around.
Had I known you had one sitting around. I would off taken it of your hands. How come you don't have it hooked up to your car? I crushed my 1G and may have crushed it a little to much. It held boost better than uncrushed but I was having idle issues with the crushed 1G so had to order new BOV.
Yes at partial throttle, the car would buck really bad. Especially in the higher gears like 4th and 5th. No matter how I adjusted it, I was not able to get rid of the bucking driving the way I drive. At WOT it works great but who drives around at WOT all the time?
Then there's something else wrong with your car that needs to be remedied, because the Forge doesn't cause that if it's in full recirculation mode.
The ONLY Forge RS to use is the recirc one
You can adjust it from stock like to a full race valve
It is an amazing unit and I have used it on at least 40 cars with perfect 100% driveability
Al, where do you recommend having the valve set at for daily driving with alky @ 25 psi? on the soft side, towards the middle or closer to the max?
