new clutch to give many a run for their money
Carbonetic/ATS & ACROSS Twin Carbon Clutches
http://www.carbonetic.net/
I had one of these installed recently and I can't say enough about it. I had ordered a Tilton with twin cerametalic, not the hybrid(I heard the organic wears out fast with good power) After waiting almost a month with my car in the shop because the material was out of stock at tilton, in which time tilton kept saying next week, next week, next week etc. My mechanic got a tip about these clutches and he decided which ever one comes in first will go on my car... well it was the Carbonetic which used to be ATS and ACROSS for jdm. In the mean time I was growing concerned about the on/off switch of the tilton. I always wanted the carbon/carbon but could not afford it.(its double the price) This carbonetic clutch package was only a few hundred dollars more than the cerametalic/cerametalic tilton. It however has the slipping ability of a carbon/carbon but at 1/2 the price of a tilton carbon/carbon. It too includes a chromollly flywheel. The bracketry is a little dubious to install (requiring minor modification.) The unit measures about 8 1/2" vs the tilton 7 1/4 and the weight is close. The lightened flywheel is a hoot. I blip the throttle and it revs very quickly. I know this is how all lightened flywheels are, but I still can't get over it. I think for the money anyone who is looking to up grade to a clutch package, this clutch should be thrown in the mix.
It also gives instructions for warm up before drag racing
I think I have one of the 1st in the country...so far so good. I will let you knowhttp://www.carbonetic.net/
The reason it is 1/2 the price of a Tilton carbon is because it uses half the amount of carbon. Tilton is full carbon/carbon (carbon driven and floater plates), which is the design of all racing carbon clutch (F1, Le Mans, etc). Carbon against steel is not really ideal. Carbon is very stable under heat and does not warp. Steel has a limited heat capacity and will warp. Once the steel plates warp, the contact area with the carbon places is reduced and torque capacity will decrease (ultimately causing a slipping clutch).
Tilton does not require any type of "warm-up" procedure to get the clutch to hold torque. All Tilton carbon clutches are tested for torque on a low speed dyno before shipping to a customer. Tilton carbon clutches hold the torque when cold. The resason you probably have to "warm-up" the ATS clutch is becuase of the difference friction coefficients between the carbon and steel plates. The "warm-up" procedure is really not a good idea for long term clutch life. The warm-up proceduce of slipping the clutch is wearing the carbon discs.
- it is a few hundred dollars more with carbon/carbon, than any other well known cerametalic/cerametalic or hybrid clutch.
it has the slipping ability of a carbon clutch
it has a chromolly flywheel
for engagement it is not an on/off switch
it is much quieter when engaged than most twin plate clutches
I will take my chances, I have friends and co workers that have used the tilton and it lasts one rally race!...thats it. They also told me that the tilton has about 2 min. of total clutch slipping time before it's toast.
I was told by a company rep that with my driving (mostly extreme street use) the clutch will probably last the life of the car. I will keep people posted
Here is more about the different materials working together. http://www.carbonetic.net/material/index.html
almost 400 miles on it...very smooth engagement for traffic driving or daily driving. I have a driveway that is up hill into a garage. I back it in and no problems stalling it, or having to over rev the motor to keep it from stalling.
about 1/2 the annoying "dual" clutch noise. The carbon plates were measured to be 2x the thickness of an exedy or tilton. Soon I will be doing hard launches with it. So far so good!
FYI the carbon plates are much thicker than the tilton, however it is true they rest against metal...but other materials instead of steel for the floater and other components which runs much cooler.
First the tilton. Don't know which tilton clutch you are talking about, but if its the C/C all I have to say is you got to be kidding. There is not a clutch on the market that compares to the tilton C/C. I own one and have first hand experience of how well it works and how long it lasts. Just reread the second post in your thread. It speaks knowledge.
The carbonetics. While I can appreciate your enthusiasm for your new clutch dont get too excited. The the exedy twin carbon, ats twin carbon, cusco twin carbon. are all similiar to what you are using and have been well tested on this board. Sorry but they dont hold up to power that well. They are smooth but they are best left to 450-500whp setups. Even at that power level they can be destroyed with one over exubant track visit.
Last the life of your car? LOL. Really fast cars (2000hp) change the clutch after every pass. Stock cars (200hp)get about 20,000 miles . Find your car on the scale of horsepower and have a realistic view of how long your clutch will last. You will sleep better at night.
Originally Posted by 4G63Rules
So much misinformation it hurts.
When I wanted a clutch he was testing the tilton hybrid...what a pos he said. He has showed me about 3-4 tilton hybrid clutches totally ruined on the organic plate. I then ordered the twin cerametalic. Tilton was out of stock and out of the material to make the clutch, for a month my car sat. My mechanic then found out about this new release. He got it looked it over compared it to every other clutch he has installed. Then he installed and tested it. Now has decicded to recommend this to all who are looking for a new performance clutch. It is not a total race like a tilton but I consider that a plus. I think there is many more street and sometime track cars out there, than all out race cars. This is all I can say...but I think it says allot. BTW my mechanic said it would last the life of MY car, because he knows my driving style and how much I drive the car. It won't last the life of a race car. my car 400+whp and 360+ tq(waiting for the official results)
Originally Posted by scott yo
the tilton carbon clutch is at the top nothing touches it for holding power\torque
You and your mechanic seem to have no knowledge on the tilton C/C. It is a full carbon carbon clutch. no metal plates. flywheel is is not a friction surface. the friction is carbon to carbon only. highest grab with the least amount of wear.
litest plates on the market, and small in diameter 7.25 for unmatched quick shifting. shifts at 9000 like it shifts at 3000.
smooth engagement, easy on the drivetrain, no noise at all from the clutch. some driveshaft noise that every twin plate will have (solid center, spring center will be quiet but is weak)
clutch life ends after .225 of material has worn from the plates.
my 550whp car has the equivalent of 400 passes on it. .012-.014 wear so far
tested at factory to hold 900ft lbs torque cold on the clutch dyno. holds more when broke in. holds more when heated. the list goes on.
the carbonetics sounds good. carbon discs impregnated with steel should be more durable than carbon only discs running on steel surfaces. but your 400hp car is hardly gonna be helpful of how good it is. when someone with 600+ goes to the track with one let us know.
cnevo8, you're obviously going to have a difficult time convincing anybody that your clutch is on par with a tilton CC. Good luck with all that....
But, way OT I know, But I have to comment on this....
That 'rock' (scirocco, for those not in the know) is the
[hotsauce]
Seriously, 10K is a steal, if I was in the market for a 183 hp FW ~monster~ I'd snap that sum***** up in a second.
[hotsauce]
FYI my mechanic has installed several twin carbon tilton's and they are on the track right now. For him to put this clutch in that class he must be impressed!
I am willing to bet that one of the 570+hp cars he tunes will have this clutch or the triple carbonetic to try out. Possibly this one http://videos.streetfire.net/categor...c902781b1e.htm I will let the people know. ?
