spark plug gap for 20psi and for 24psi of boost
Old Aug 24, 2006, 06:30 PM
drewblueeye's Avatar
what should i be gapping my spark plugs at for 93 octane at 20-21psi of boost and what should i be gapping them at for 97 octane at 23-24psi of boost?
Old Aug 24, 2006, 06:49 PM
Schuyler's Avatar
Stock gap is .7 - .8 - I don't see any reason to change that on a stock turbo.
https://www.evolutionm.net/forums/sh...d.php?t=118252
Old Aug 25, 2006, 02:51 PM
gsrboi80's Avatar
I gap mine to .026 in. Above in mm
Old Aug 26, 2006, 01:58 PM
blkdinan's Avatar
Had problem with boost blowing out my spark around 24psi. Had a local tuner upgrade my ignition with a custom setup and will never have problem again.
Old Aug 26, 2006, 02:10 PM
smokedmustang's Avatar
I am at .022
Old Aug 26, 2006, 02:15 PM
sparky's Avatar
Originally Posted by smokedmustang
I am at .022
How many PSI you running at smokester? And is that with 8's?
Old Aug 26, 2006, 02:18 PM
Yes it is with the NGK BPR8ES and it is about 25psi on the 2.0L motor I had. that is with the HKS DLI spark amplifier also. I am keeping it the same gaps with the stroker motor/shooting the meth.
Old Aug 27, 2006, 06:50 PM
the reason i ask about spark plug gap is because i bought a turbo and supercharger book and according to that book and al other resources i have read that "...When you run higher boost you must regap your spark plugs to a smaller size. The reason for this is because when you pressurize your cylinder chambers it actually makes the gap larger with all the pressure built up. Therefore if you run higher boost it makes the spark plug gap even further apart, which may cause a Service Engine Soon light to come on."
And i never had a problem with the light coming on until i started running higher boost. that is why i asked what your guys are gapping them at.
I will try .022 tomorrow
Old Aug 27, 2006, 06:53 PM
It works for me, and if you have the BPR8ES plugs, they will need to be changed more often. I change mine at 4K miles. if I originally gapped them at .022, at 4K miles, I re-check the gaps, they are all at .030. so just be aware of that. you will be fine.
Oh and i am running the NGK BPR7ES, which is what Buschur Racing recommended with the my upgrades.
Old Aug 27, 2006, 06:55 PM
I change my plugs everytime i change my oil, every 3000 miles.... maybe that is to often but i dont mind
Old Aug 27, 2006, 07:03 PM
You will be fine my friend!! drive safely!!
Old Aug 27, 2006, 07:30 PM
thanks smokedmustang
Old Aug 27, 2006, 07:55 PM
Anytime!!
Old Aug 28, 2006, 07:22 AM
SSKILLA's Avatar
same here...im at .25 and i change mine every oil change....there only a 1.25 ..lol
Deanooo
Aug 25, 2016 05:17 AM
Svendiesel
May 10, 2010 03:19 PM
Oracle1
Mar 30, 2008 09:57 PM
evilevo2003
Mar 10, 2008 11:13 AM
Derek888
13
Dec 9, 2005 12:26 PM
Quick Reply: spark plug gap for 20psi and for 24psi of boost
