Official torque specs thread
Old Sep 11, 2016, 10:07 AM
  #136
Vigman's Avatar
Its likely, Cosworth would refer all torque specs per the manufacturer
This was taken from the manual. 18ft lbs. Not sure what you meant by CR? Please double check this info
Thank you Minus Previous!
CR: Connecting Rod.
I wrote Cosworth and they do not supply any value, unbelievable!.. I guess manufacturer settings is a good start.
Cheers!
MinusPrevious (Sep 11, 2016)
Old Sep 11, 2016, 03:22 PM
  #137
Received 1,384 Likes on 1,317 Posts
CR: Connecting Rod.
Cheers!
Yes, Connecting rod. Here it is if needed. Taken from EvO 9 manual
Old Sep 11, 2016, 03:38 PM
  #138
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
Do not use the OEM connecting rod bolt torque spec on your cosworth rods. It will not work.
Also, if you bought main studs, do not use the torque specs for the OEM bolts.
The OEM bolts are torque to yield bolts. Hence the torque spec is XXft-lbs then an additional 90*. The manufacturer has to do a good amount of testing (with the bolt and the assembly) to come with a torque spec like that.
I find it quite deplorable that cosworth doesn't have torque specs for their parts. Do the heads of the rod bolts have markings on them?
Old Feb 17, 2017, 12:07 AM
  #139
matthunter1448's Avatar
needed this info thanks
Old Jun 12, 2017, 07:02 AM
  #140
bakuro117's Avatar
Does anyone know if there is a torque spec for the oil passage plug on the back of the cylinder head just above the EGR port? Please see pic below for reference. I've skimmed the service manual, and tried a few searches here, but haven't had any luck finding the specifics on this little guy.
Thanks!
Old Jun 12, 2017, 07:20 AM
  #141
It's pipe thread. Put thread sealant on it, and snug it up. It's not going to go anywhere, the threads are tapered, it basically wedges itself in place.
Old Jun 13, 2017, 06:50 AM
  #142
bakuro117's Avatar
Got it taken care of last night. Thanks for the advice. Just wanted to double-check that there wasn't a factory spec anywhere.
Old Jun 25, 2017, 12:47 AM
  #143
chizz's Avatar
whats the torque settings for the flywheel on an evo 4? and the pressure plate to flywheel? thanks
Old Jul 18, 2017, 09:38 PM
  #144
EV09AWD's Avatar
Huge thanks,
this helps tremendously. +Rep
Old Sep 26, 2017, 06:45 PM
  #145
jlcann1's Avatar
Very helpful
Old Jul 13, 2018, 06:21 PM
  #146
EvoStevo777's Avatar
Anyone know the torque specs for turbo studs that connect to the exhaust manifold
Old Jan 7, 2019, 02:19 PM
  #147
boostedwrx's Avatar
Difference in torque specs in the repair manual. I circled the fasteners in question.
The m8 manifold bolts are 22+-2 ft/lb on one, 24+-4 on other. M10 nuts 36+-4 on one, 41+-6 other. Not huge diff there.
Manifold to turbo bolts and nuts are 38+-3 one, 47+-3 the other, however Nm is the same at 64+-5 Nm. 64 Nm is 47 ft/lb.
I’m thinking the greater of the figures is the correct one as the fsm manifold torque sequence references the greater numbers also. Although 47ft/lb on the turbo bolts seems a little high, I always did around 40 I thought..
Old Jan 7, 2019, 05:37 PM
  #148
You can't really "torque" the smaller manifold to head bolts with most aftermarket manifolds, so I just guess at 25ftlbs on those. The big ones on the manifold get 40ftlb. And on the stock frame stuff where I can use a torque wrong on the turbo to manifold bolts/studs, I do 48ftlb. Or in the case of basically any aftermarket mani, even stock frame stuff, they just get made tight because theres no torqueing them.
Old Jan 8, 2019, 09:43 PM
  #149
boostedwrx's Avatar
Just weird the fsm has different specs, but they’re all close enough I guess like ya say. On the FP cast there’s about enough room to get a deep flank crowfoot on the top row. The bottom is fine. And I got a new made in Merica CDI torque wrench to use
Old Jan 8, 2020, 04:10 PM
  #150
UrbanSmoker's Avatar
Hey guys, I didn’t see it on here but I need the torque spec for the alternator pulley, I’m replacing mine with an Stm 10% under drive. Also if anyone has a good technique on how to hold the oem pulley so I can remove the nut that would he awesome
Quick Reply: Official torque specs thread
