mbc install help
Old Nov 6, 2006, 07:33 PM
projekt_shocker's Avatar
mbc install help
I need your help about my mbc i just installed this evening..
This is how I did my install. I use the MBC Source where the "T" is at connected at the turbo nipple. and I hooked up the mbc outlet source to the wastegate.
The wastegate actuator is still plugged in with the hoses that are "T" with the turbo nipple and the intake.
my boost with the (-) all the way up to its max. is boosting at 21 psi ?!?!
i tried to look for vacuum leaks and find nothing there... i wonder whats the problem?
Old Nov 6, 2006, 07:37 PM
dubbleugly01's Avatar
Get rid of all the "t's" in your install. Turbo nipple outlet to the MBC inlet. MBC outlet to the wastegate. That's all you need.
edit: oh, and just cap the now spare nipple on the turbo intake.
Old Nov 6, 2006, 09:01 PM
got it THANKS! MBC works great but i cant go any higher than 17 psi or it will fuel cut!
I need a fuel pump and tune REAL BAD... those 2 are my next mods...
galantman03
43
Feb 5, 2017 09:54 PM
Flyhigh
Nov 29, 2016 04:10 AM
drb
53
Oct 25, 2016 07:50 AM
Yakshii
Sep 14, 2010 09:04 AM
AutoEuphoria
Jun 21, 2006 09:24 PM
Quick Reply: mbc install help
