How can you tell your oil pump is bad?
So I have an 03 Evo with about 98,XXX miles on it. About 2 weeks ago after getting of the high going into baltimore I hear the DREADED ticking noise. Of course I shut the engine off and checked oil. It was @ the lower mark so it wasnt dangerously low.
Anyways I took it to a local repair shop and they told me either my oil pump was going bad or my my bearings were bad main or rod. I dont remember. So will that oil light come on when its low pressure or will the CEL light just come on an 03 evo or is that 05 and up? The ticking gets louder as I go faster. Ive always used 10w30 mobile one. Im thinking of buying a oil pressure gauge to see if the pump is losing power.
Let me know if anybody had to change their oil pump or bearings on a stock engine. Just have some 272 cams in the car currently.
That is basic engine 101. You need that gauge to moniter the health of the car at all times. They are only around $50.00 for a Stewart Warner gauge. Also...if the pump lost pressure I believe the oil light would come on. The best thing to do if you want to isolate the ticking is to get a long extension or screwdriver and with the car running use it like a stethoscope. Place one end against the block and the other in you ear. Listen to the ticking and follow it until the sound is as loud as it will get. See where it is in relation to the block and it components. This should help if its the oil pump.
Also...drain the oil and check for metal. If the bottom end is coming apart there should be metal in it.
Buy the oil pressure gauge. Get a boost gauge. If you have money left over, invest in a wideband O2 sensor w/gauge. These should be some of the first mods you ever do to the car.
Mobile 10W30 is a motor job waiting to happen. 20W50 is what to use.
People have had to change their oil pump. People have had to rebuild their motors because of main and/or rod bearing failure. They can all happen. What has happened in your case is individual. Have you drained the oil, looking at it carefully to see whether you have debris and metallic particles in your oil? I'd start there, if you suspect bearing failure, and then if you're still not sure, pull the oil pan and check out the mains, rods and balance shaft bearings as well.
Definately changed the oil and no metal. Ill try the screwdriver thing. plus get an oil pressure gauge. when my ear is on the head of the car its really loud especially on cylinder 3 towards the intake side of the engine. Thanks for the info.
Oil Pressure gauge and screwdriver.
japspec (Jan 12, 2020)
Mobil 1 10W30 FTW or if you are racing maybe you could go Mobil1 15W50....Either way I doubt the viscosity of the oil caused your problem....
