what you guys think !! Evo VII
Hi all
First of all ,,,, my english is not very good
2nd thing ... this is the best forums i`ve ever seen
3rd thing .. I own Evo VII
Mods :
FUJITSUBO Downpipe
3 inch cat delet
Blitz NUR Spec R Exhaust System
HKS Air Filter
Walbro 255lph Fuel Pump
I am going to buy this parts (need ur comments & opinions) :
1- Duoble Plate Clutch ,,, Exedy or CUSCO or what ??
2- Apexi Power FC ECU ... whats the maximum boost i can ran with stock injectors ? do I need to get bigger injectors ??
3- Sard Fuel Regulator.
4- 272 Camshafts & Camgears ... in & ex .. maybe HKS or JUN
what do u guys think ... is there is anything I miss ??
and do I need a boost controller to turn up the boost ?? or the Apexi Power FC can turn up the boost??
How much HP should I expect with all these parts ?
by the way I am running now 19 psi with 95 octane
Mods :
FUJITSUBO Downpipe
3 inch cat delet
HKS Air Filter
Hi all
Mods :
FUJITSUBO Downpipe
3 inch cat delet
HKS Air Filter
Mods :
FUJITSUBO Downpipe
3 inch cat delet
HKS Air Filter
A friend of mine was running 30 psi on pumpgas/alky injection on the stock injectors so they should be fine if you go with that combo.
Jun Camshafts are radically more powerful than the HKS however they aren't recomended for stock head evos. They are more for full out drag Evos with larger turbo's. They will shine there.
A better choice would be HKS 280's or GSC 280s if you want to stick with the stock head.
Also a double plated clutch is a tad over kill for the listed mods but it's your money.
Anyhow welcome and lets see some pictures!
ahaa...so you are from Oman?? good stuff man..thats like 2.5 hours from dubai where i live...drive down to dubai..i will show you around..i will take you to the evo garage here in dubai...
by the way devil evo...we have ecuflash here in dubai..i would recommend that over the Power FC because the tuner knows what he is doing..he has tuned tons of evos from all over the place...whereis the Power FC is not so populat here..
Good Luck
Good Luck
Good Luck
Good Luck
yes I am from Oman - Muscat and i have a lot of friends from dubai & sharjah ,,, btw who do the reflash ... which garage ?and how much it costs
telephone numbers plz if available
Hello there
If youre not going for mental power why not go for 264 cams
as for the clutch it all depends how hard you are on your car really.
get a flash done (underestimated especially over in my neck of the woods).
Thinking about it ditch the stock manifold and turbo elbow too
Stick a avcr on while your at it and your laughing
Liking the yellow VII
