Pros/Cons of 100%meth or 50/50 mix
Old Feb 17, 2007, 02:12 PM
MRevolutionRed's Avatar
i am buying a meth kit very soon and wanted to know what the benefits are of running 100% meth or 50/50 mix(or whatever the mix may be). what are the pros and the cons of both? will running less meth hurt my power but be better for the car?
Old Feb 17, 2007, 02:16 PM
cij911's Avatar
It depends on the kit you go with....Aquamist kits are made to run 0 - 100% Meth....
4WS Tuning's Avatar
100 = more power but more corrosive to the meth kit
50/50 = little less power but the kit will last much longer and its much cheaper to run.
thats it really... i run 50/50 drops the cost to 2.00 a gallon and i use a gallon of the mix a month. uber cheap!
Old Feb 17, 2007, 02:25 PM
sounds good to me the think i am gonna go with the aquamist kit cuz i need to be safe and i hear they are the best right now.
Old Feb 17, 2007, 02:43 PM
Ultimate CC's Avatar
+1 to that...I did extensive testing with the evo and found there to be no gain over 50% on the stock based turbos...
Old Feb 17, 2007, 02:48 PM
Warrtalon's Avatar
UCC, that's just one example. 100% has a good bit more power potential than 50/50.
OP, there's nothing special about Aquamist in terms of safety. If you're referring to failsafes, then fine, but you don't even have to run meth if you're worried about corrosion. I run 100% denatured alcohol, because it's not toxic, and because I can get it just about anywhere. Meth is harder to source, but it's cheaper. You can run 100% alky in any major kit with no worries whatsoever.
Old Feb 17, 2007, 02:56 PM
EvolvinEvo's Avatar
i run 50/50 as well, got dyno tuned with a few other evos 8's and 9's running 100% meth with similar or more mods than me and somehow i still made the most power
Old Feb 17, 2007, 02:58 PM
4WS Tuning's Avatar
you can get a snow kit for around 400 with a fail safe.. i've been running it a little while now it and its bullet proof. very easy to install most importantly. the aquamist you probably want to take it to a shop and pay another 100-200 for an install.
cheers!
Old Feb 17, 2007, 03:01 PM
smokedmustang's Avatar
100% Meth will lead to washing out of the cylinder bores, and nullify the protective properties of the oil, from what I am told, from someone who knows. I will go find what he says, and post it over here!
Old Feb 17, 2007, 03:07 PM
I am not referring to just my evo...there are several customers that I have tuned and have been tuned that all put down nearly the same trap speeds and dyno numbers as people with 100%...
Old Feb 17, 2007, 03:10 PM
DS-03evo's Avatar
Warrtalon- Is there a difference in power, meth vs. alcohol? Will the tune have to different for each?
Old Feb 17, 2007, 03:13 PM
methanol makes a few more whp than alcohol...the tunes will be similar as far as timing goes but the fuel will be different...
Old Feb 17, 2007, 03:17 PM
Jerry (94AWDcoupe ) can explain about the washout if you want to ask him, or he will post here if he sees this. I say mix 75% MEth and 25% distilled water, and forget about it.
Old Feb 17, 2007, 05:55 PM
Mercenary3's Avatar
huh? Methanol is an alcohol.... you mean more whp than ethanol?
i dk what to do now..lol.. i want to make the most WHP possible but be safe...now methanol or alcohol? willl the gains be the same?what is safe and better.. im really looking into the 50/50 mix meth, distilled water.
Quick Reply: Pros/Cons of 100%meth or 50/50 mix
