transfer case
Old Apr 8, 2007, 09:05 PM
mitsu IX's Avatar
transfer case
I have a evo IX and I just changed all my fluids. When I changed my transfer case the oil was dark. Is that normal or will I have to get work done on my transfer case. I only have 15,000 miles on the car and no modifications.
Old Apr 9, 2007, 07:50 PM
jezefink's Avatar
its an evo..alot of people have problems with the transfercase....
Old Apr 9, 2007, 08:18 PM
iTune's Avatar
metal shavings?
What kind(and amount) of metal shavings were on the drain bolt for the TC? It's fairly normal to have oil that is dark after that amount of time. The metal bits/shavings on the TC drain bolt tell you everything.
same goes for the transaxle and rear diff.......
CJ
Old Apr 10, 2007, 12:24 AM
94AWDcoupe's Avatar
if oil is dark that means the gears are wearing out. expect it to start whining very soon.
Old Apr 10, 2007, 05:18 AM
joeMama's Avatar
dark like paint or dark like burned?
Old Apr 10, 2007, 05:28 AM
Luis@TTP's Avatar
its normal for the oil to be dark nuthing is wearing out the transfer case carries a certain amount of heat that cause the oil to turn the burnt brown color it has done no harm internally to your tc unless there are large chunks of metal falling out of it.
Old Apr 10, 2007, 05:30 AM
Clutchdc5's Avatar
oh god, TTP saved my day, i was starting to get worried reading how dark is no normal , haha
Old Apr 10, 2007, 05:37 AM
Luis@TTP's Avatar
Old Apr 10, 2007, 06:04 AM
rcheung's Avatar
I dont know if its normal but I changed mine about every 15k miles and it always came out looking like the same color it went in with diaqueen.
Old Apr 10, 2007, 06:53 AM
beyond1's Avatar
same here.. its pretty dark... also question to u guys ,,,i hear a little whinng noise in the rear if u stick ur eat at the rear tire ...u can hear it.. u think its my tc going bad . i have 26k on the meter ..i change the tc oil 15k ...what u guys think should i bring it to the dealer
Old Apr 10, 2007, 06:55 AM
Jeff_Jeske's Avatar
Dark with a green shade is completely normal. You have nothing to worry about.
Old Apr 10, 2007, 06:58 AM
4ringturncoat's Avatar
Not to worry. Pour some Diaqueen into a clear container, it's dark to start with.
Jeepyedo
Jun 28, 2016 10:57 PM
silkyjohnson
Mar 12, 2011 12:15 AM
daracer18
May 12, 2008 06:55 AM
Cinci Turbo IX
Oct 1, 2007 05:00 PM
J-ROC
21
Sep 25, 2007 09:32 PM
Quick Reply: transfer case
