Blown Engine, Change the Oil Cooler?
My engine Blown(long history) and some metal particles are arround, can i wash the oil radiator or Change it for a new one???
Help Apreciated
Help Apreciated
Spun Bearing? Rod Knock? Just curious what happened.
I had a small amount of Rod Knock, the IX was stock and the dealer confirmed the bearings were worn. They replaced the bearings (Rod and Crank), polished the Crank and new Rod Bolts. They flushed the OIl Cooler and Turbo, to make sure there was no particles left behind.
The oil is filtered before the oil cooler. Just back flush it. I have a pressurrized solven tank kit I use just for this scenario. Spray brake cleaner or parts solvent into the oil cooler. Then use some compressed air to blow it all out.
racer135
19
Feb 1, 2009 08:57 PM
TampaTurbo
23
Oct 20, 2005 04:44 PM
