Vibration in Gas Pedal, Rough Clutch
Old Oct 29, 2007, 05:58 PM
silverevo05's Avatar
Stock
Lately I've been getting a Vibration on the gas pedal (not really at the steering wheel) at almost any speed, esp around 75 to 80 mph after 80 it seems to smooth out
If im in neutral and press the pedal its smooth.
I also get a relly rough clutch pedal feel, i.e. I can feel the rpm and engine movement thru the clutch pedal when releasing the pedal after chaging gears, though if while in motion I just depress the clutch pedal (in neutral) its smooth
I've ruled out alignment because the pedals work smoothily when i'm not engaged.
Old Oct 29, 2007, 07:03 PM
anyone?
Old Oct 30, 2007, 10:34 AM
any help or ideas would be greatly appreciated
Old Oct 30, 2007, 10:40 AM
JDMLancerEvoVII's Avatar
How many mile and what year?
Old Oct 30, 2007, 11:20 AM
06 9k
Old Oct 30, 2007, 02:48 PM
Vibration on clutch pedal will occur on any gear between 2300 and 3100 rpm?
what does this mean???????
Old Oct 30, 2007, 06:18 PM
Mitsu3's Avatar
i have the same car and i kinda have this too...maybe the clutch or flywheel is warped thats the only thing i can think of b/c i did burn my clutch a couple of times
Old Oct 31, 2007, 08:56 AM
does your gas pedal vibrate as well (mine is sometimes enough to put my foot asleep)?
Old Oct 31, 2007, 09:09 AM
smokedmustang's Avatar
Have either of you changed cams or the timing belt BEFORE you noticed this "Vibration?" If so, you might have the oil pump balance shaft out of sync. Look up this thread:
https://www.evolutionm.net/forums/sh...d.php?t=159892
Not sure if this is the thread, but I had the same problem.
Old Nov 1, 2007, 08:54 AM
nope havent changed anything
Old Nov 2, 2007, 05:42 PM
would the fact that it happens at a certain rpm rather than a certain speed, mean that this is engine related, suspension related or what?
Old Nov 2, 2007, 06:32 PM
IXToes's Avatar
I think I'm getting signs of the same problem. 12k miles Evo IX.
Old Nov 3, 2007, 11:21 AM
Ixtoes have you taken yours to the dealer or anyone smart enough to figure this prob out?
Old Nov 5, 2007, 07:07 PM
su37su's Avatar
same problem here, but only clutch pedal is rough.
15k miles 06 IX.
evoforstevo
Jul 21, 2017 05:07 PM
bbong
Jun 11, 2017 05:25 AM
cts4g63
Jan 6, 2016 02:22 PM
nor11384
Nov 22, 2015 01:31 PM
deegaw11
13
Feb 27, 2007 12:20 PM
Quick Reply: Vibration in Gas Pedal, Rough Clutch
