Do You Guys/Gals no What this might be??
I had my headgasket replaced not to long ago. The funny thing is that the coolant overflow tank still empty its self out. Its not fast like a headgasket would to but its slow and takes a week. I dont see any on the floor in the garage
Probably burning coolant or like one guy said you didnt have the radiator all the way full so it pulled it out of the reserve. If your burning coolant you might also have some oil in your reserve tank. so Check for that
if its the headgasket or warped head that would prolly be whats causing it to burn coolant. white smoke is a real good sign of a blown headgasket. since your not really seeing that. It might mean your just very slightly burning coolant or its leaking somewhere. or leaking onto a hotspot then evaporating/burning
did you take off the oil cap and see if its a brown milky color, dont check just the dip stick, take off the cap and look inside. You could have just a small leak, they have sealant stuff for that. It might help, but since you just had the gasket done it should be under warranty.
do a pressure test of your coolant system.
