bad mbc or bad wastegate???
i installed my ets 57 trim kit last week.. went to up the boost today as i had my forge mbc all the way down,i hit 16-18psi not sure 100% i tried every click and mbc all the way up and the boost wont move...
i tried disconnecting the vacuum line from the mbc to the wastegate, and same thing 16-18psi....
whats wrong???
whats wrong???
checkd for boost leaks yesterday, a very tiny one @ 25psi out of my throtle body seals but nothing major, the new seals are going in... no way would it effect my boost more than 1-2 psi at most.... no other major leaks... i confirmed twice the lines are hooked up right
btw its a tial 38mm wastegate and im using the bottom port for the line, and the top is venting to atmosphere, maybe thats not how it should be??but i didnt notice any boost leak there
Also Post up a example of how your setup looks, it will help us help you. or describe it.
right now sounds like a hose issue....
but ck inside that MBC...i know i had leakage issues with mine...but my issue was boost would not go below 24psi.
turned out to be the damn greddy type s diverter valve? replaced with a stock 9 and no problems lol.. only issue is at idle the car ends up basically stallling now, must have someting to do with the tune
galantman03
43
Feb 5, 2017 09:54 PM
MajesticOne
Nov 20, 2016 02:34 AM
