Switched Back from MBC to Stock Config
I took off my MBC and switched back to stock configuration. Now my car only boosts .80 BAR. The only difference is that I used new vacuum lines for both the wastegate and the nipple from the turbo housing. Any ideas anyone?
FYI
12413AS is just a reference number. The real part number is MN143555
There is a restrictor in the hose that connects to the turbo housing and the one leading to the boost control solnoid.
Sounds like your wastegate is running it's static pressure as if you had a mbc connected but turned all the way out to the lowest setting. There is a restrictor in the line going from the turbo to the t-fitting to the wastegate and also another one going from that t-fitting to the factory solenoid as well. Not sure if this will do it but could be an easy fix. Also make sure that the lines are hooked up properly to the wastegate.
jorge mr
10
Nov 30, 2008 01:38 PM
nikkadanny
May 19, 2008 08:07 AM
