Fluid capacities and recommended lubrications
As I'm browsing through the forum threads there are way to many people asking how much of such and such fluid should they put in their car, thus I'm going to post Mitsubishi's suggested amounts of x fluid for a 2006 Evo MR straight from the owner's manual. Yes, please read yours if you have it as it'll answer a lot of the topics found on this forum.
Fuel (approximate):
14 gal (53 L)
Engine oil: Fully synthetic SAE 10W-30
Oil pan = 4.8 qt (4.5 L)
Oil filter = 0.32 qt (0.3 L)
Oil cooler =0.52 qt (0.5 L)
Power steering:
1.1 qt (1.0 L) Mitsubishi power steering fluid
Manual transaxle:
(5 M/T) = 3.0 qt (2.8 L) DiaQueen New Multi Gear Oil API classification GL-3, SAE 75W-80 or Gear oil API classification GL-4, SAE 75W-80/75W-90
(6 M/T) = 2.3 qt (2.2 L) DiaQueen New Multi Gear Oil 75W-85 (GL-4) or exact equivalent
Transfer oil:
0.63 qt (0.6 L) Mitsubishi LSD oil or equivalent
Rear axle differential:
0.58 qt (0.55 L) Mitsubishi LSD oil or equivalent
Active center differential control fluid for hydraulic pipping:
0.95 qt (0.9 L) Diamond ATF SP III
Brake and clutch:
As required (check the reservoir in the engine bay). Brake fluid DOT3 or DOT4
Engine coolant:
6.3 qt (6.0 L) Long life antifreeze coolant or an equivalent
--Include 0.69 qt (0.65 L) in reserve tank
Also, here's a link to understanding the different API categories should you have any:
http://www.finalube.com/reference_ma...Categories.htm
Enjoy,
-Pao
Fuel (approximate):
14 gal (53 L)
Power steering:
Manual transaxle:
Transfer oil:
Brake and clutch:
Engine coolant:
Enjoy,
-Pao
chaotichoax
Jun 8, 2020 06:10 AM
kyoo
92
Feb 25, 2019 07:16 AM
75w80, api, atf, capacities, classification, diamond, diaqueen, equivalent, fluid, gear, gl3, iii, mitsubishi, multi, oil, sae, sp
