Is my TOB going bad
Is my TOB going bad
Starting making the noise last Friday(25th). It always made the common noise of the TOB at idle.
But Friday it started making the noise in 1st gear up to about 3000rpm's then it goes away. Doesn't do it in any other gear at any rpm or speed. Only 1st gear. There's no whine from TC or clanking or grinding from the tranny just the noise of the TOB turning faster until 3000rpm then its gone.
Now i just want to see if you guys think it's also the TOB.
And will any TOB from a clutch kit for a Evo will work. I have a Exedy Stage 1 in there right now. Clutch has been in for about 20,000 miles had a whole new kit put in at the time so the Tob only has about 20,000 miles on it.
The noise is like a clunking at idle, its flait not real loud, If anyone has every heard the TOB at idle on there car thats the sound.
yeah, i have the TOB noise at idle, then push the clutch and it goes away, but now when i start off from a stop you hear it up to 3000rpm then it goes away in 1st gear, other gears no noise what so ever.
Dross99_si
13
Sep 16, 2016 10:57 PM
WickedWhtMR
167
Mar 12, 2016 04:26 PM
