problems shifting in to reverse.
Old Aug 27, 2008, 08:21 PM
RomansEVO8's Avatar
I just changed my tranny and T-case fluids, (redline lightweight), and my car doesn't want to shift in to reverse. First is kinda hard to get in to also.
Old Sep 10, 2008, 02:26 AM
Short-Bus's Avatar
+ 1 i have the same problem right now someone please help
Old Sep 10, 2008, 03:03 AM
allison's Avatar
make that +2
Old Sep 10, 2008, 05:56 AM
mike1023's Avatar
try to go to first and then revers. make sure was right fluded also.
Old Sep 10, 2008, 06:20 AM
quick silver 8's Avatar
^^^^^^^ what he said, first then reverse. i have the same problem
Old Sep 10, 2008, 06:27 AM
sharkm87's Avatar
...i always do 4th than reverse...than again i dont have this issue....force of habit though
Old Sep 10, 2008, 06:31 AM
MEVOLV3's Avatar
Is it only when the car has been started for the first time of the day or constantly?
Old Sep 10, 2008, 06:48 AM
Ev0cRaZy's Avatar
Im pretty sure reverse isnt syncronized, therefore you need to put it in first or whatever gear and then go to reverse, it will go in just fine. You cant just try to ram it into reverse right off.
Old Sep 10, 2008, 07:24 AM
Knguyen228's Avatar
Same problem here, when that happen I just shift into different gears, then go into reverse. Always work for me.
Old Sep 10, 2008, 04:56 PM
Short-Bus's Avatar
in my case i cant get into first or reverse!!! i just installed a clutch and bled the lines several times. we adjusted the pedal. also when i try to go into first or reverse i can feel the car try to move as in the clutch is not completly disengaged. does anybody have any ideas that would help me fix this damn problem i really dont have to have to take the whole car apart again for this lol
Old Sep 10, 2008, 04:59 PM
btownsoccer22's Avatar
i go through all the gears once i start the car that usually works
Old Sep 10, 2008, 05:00 PM
SLO-EVO's Avatar
you need to check to see if you put the shifter linkage back on the right way...
Old Sep 10, 2008, 05:08 PM
Knguyen228's Avatar
^^something similiar happen to me once! I could not go into 1,2,5,6, and R. only 3rd and 4th would go in. something about the linkage came loose or something. Mitsu towed and fixed it.
Old Sep 10, 2008, 05:26 PM
SLO-EVO's Avatar
if you dont have the pins in, or the arent aligned perfectly, it will not allow your car to shift correctly... the linkage is right below your uicp and your battery...
Old Sep 10, 2008, 05:35 PM
Knguyen228's Avatar
Mitsu installed the clutch so it was there fault.
Quick Reply: problems shifting in to reverse.
