Can i hit 500awhp?
Can i hit 500awhp?
I have an Evo 8 with the following mods
Turbotrix bb50trim kit .63 a\r w/ TiaL 44mm external Wastegate
Turbotrix custom downpipe
Turbotrix custom lower IC pipe
Custom upper intercooler pipe
RNR intercooler
custom made intake
Megan Cat back exhaust
Weapon R oil catchcan
denso 720cc injectors
walbro 255lph pump
Hks 272/264 cams
AEM Tru boost
AEM UEGO widband
New OEM headgasket
ARP Headstuds
Aquamist hfs-1 methanol injection running 50/50 mix
Do you think its possible to hit 500awhp on 93 octane + meth? If not, is there anything i can do to hit 500awhp on 93 octane and meth?
What power do you think i COULD hit with my current set up? With my current tune my best track time is 11.50 @ 124.7mph
RNR intercooler
custom made intake
walbro 255lph pump
Hks 272/264 cams
AEM Tru boost
AEM UEGO widband
New OEM headgasket
ARP Headstuds
Its very possible to hit 500whp on that turbo. It all depends on the dyno you are using tho . People have been able to make 500whp on stock appearing turbos, look at 9sec9 he is getting close to breaching the 600whp mark on a stock appering turbo. Bottom line is it comes down to your tuner and the dyno you end up using. Can you make 500whp on a dynojet, possibly. Can you make 500whp on a Mustang Dyno, now you are stretching it out a little. Either way just make sure that you have a really good tuner.
you might need to get 272 all around on your cams and gigger turbo kit also someone told me i needed bigger injector than 750cc just for 500whp so you might wanna look into that
Alright so the general opinion is go with a 35r or red.
What will those two spool up at? the 50trim bb is at about 4,000rpms right now.
Im in the mass/new hampshire area so who would you reccomend for tuning? do NOT say dsg, we arnt even going into that one.
I was thinking of having dynoflash, off of here, do it.
So what exactly would i need to do to switch over to the 35r or red? Just the turbo or the full kit?
