my gas pedal sticks help
sup man, I would check the pedal itself and make sure its not getting stuck on something, also check the throttle cable in the engine bay. a little bit of lube might help too. i got some synthetic grease if you need it.
dennis
dennis
1 Post
check to see if the rubber stopper is still behind the gas pedal. Mitsubishi install this rubber stopper to prevent the driver from "hitting the pedal to the metal!" My buddy's 08 evosis was doing this as well. The removed the rubber stopper and voila, no more pedal being stuck.
Maybe this'll help you maybe not. Best of luck to you.
2003, 2006, accelerator, evo, evom, gas, lancer, mistzubish, mitsubishi, pedal, rubber, sticking, sticks, stopper, stuck
