Where can i buy a "rally" style E-brake?
Old Jan 29, 2009, 03:47 PM
Trail Slide's Avatar
press button, or something different than OEM? i cant find anything and looked everywhere. i heard there are devices that let you disable the E-brake "click"
any info?
Old Jan 29, 2009, 04:57 PM
666 EVO's Avatar
Most rally cars use a hydraulic e brake that controls the rear brakes when you pull it. Because over time it stretch the cable and because useless. http://cgi.ebay.com/ebaymotors/Kspor...4506.m20.l1116
But if your looking to use yours just take the button out that forces the locking pin down.
Old Jan 29, 2009, 10:12 PM
DaveK's Avatar
Push the button in, then while holding it in, drill a hole from the left side thru the button out the right side of the handle. Then, when you want the ebrake not to lock, slide a pin thru the hole you drilled.
My evo has a hydraulic handle installed, but as the previous poster mentioned, its not something you can just install in place of the stock one, it required re-plumbing the rear brake lines.
Dave
Old Jan 30, 2009, 12:25 PM
Epix_'s Avatar
http://www.driftnamiperformance.com/...s-cusdbtmm.htm
Cyrax91
Aug 7, 2017 08:18 AM
[GBU]Moon
11
Apr 29, 2016 06:23 AM
houckeah
Dec 25, 2008 01:39 PM
WillEatUrSTi
Mar 18, 2006 11:12 PM
Quick Reply: Where can i buy a "rally" style E-brake?
