Competition Clutch Flywheel/Clutch Install on Evo IX RS
I have an Evo IX RS at 30,000 miles and just had a Competition Clutch flywheel (part STU ultralight) and clutch (stage 4 six puck) installed. We used the TO bearing included in the CC kit. I used factory Mitsubishi Diaqueen 75W85 for the tranny, and Mitsubishi LSD gear oil for the transfer case and rear diff. I paid $700 for all the parts and $500 labor.
CC Stage 4 clutch kit:
CC Clutch #STU:
I had an Evo tuner and BMW certified tech install everything at a local shop. Everything in my car is now broken in after a week and about 400 miles. At first there was more clutch chatter at idle and noticable vibration in the pedal, however, this gradually went away. Now after break in there is no vibration in the clutch pedal, and the clutch chatter at idle is back to normal. The car drives great, and shifts/engages better than stock.
However, there is one noise that I can't seem to explain.
In first gear there is a loud resonating whine when accelerating from a stop. It almost sounds like a low volume car horn, like a resonating metal sound that's smooth, not grinding. Here's the thing, if I do a light launch with revs at 3k and slip the clutch a bit, then the noise goes away for a while. However, it does return later, and usually happens on a cold start up too.
It almost seems like the clutch and flywheel are making that noise once they engage as I slip into 1st gear from a stop, maybe the flywheel still has uneven surfaces that need to be broken in. Or maybe this is something normal for an aftermarket clutch/flywheel setup?
Overall though, the tranny shifts great while accelerating easy/hard, engages very well when downshifting, and holds power great. It's just this odd noise that I was wondering if anyone else has experienced.
CC Clutch #STU:
i just had a competition stage 4 6 puck clutch installed 2 weeks ago professionally by a well respected speed shop is this whats happening to your car? https://www.evolutionm.net/forums/ev...need-help.html Click on video links
Only happens when accelerating in 1st from a dead stop. It goes away if I do a mild launch with clutch slip, but returns later. Or if I slip the clutch quickly and at the right time it won't make the noise. Only difference from your setup is I also put in a Competition Clutch ultralight flywheel (part# STU) along with the stage 4 six puck clutch.
I called Competition Clutch directly a few hours ago and the tech said the sound was normal and I should break it in more. I have 400 miles and 8 days, I'll keep driving and see if it goes away. It makes me feel a bit better now that someone else has the same issue, I think it will go away with time.
It doesn't worry me as much because the noise does go away with a light launch/clutch slip, so it could be just engagement noise that comes with aftermarket parts or imperfections on the flywheel surface that need to smooth out. Plus the noise is more of a resonance and NOT grinding. Other than this noise in 1st gear, the car drives better than before, shifts great, engages great with the engagement point at the top of the clutch pedal travel, just like it was when stock.
I'll keep breaking the clutch in and will update this thread in the coming weeks.
Dude, I have the EXACT same noise. Sounds like an elephant moaning, like a resonance. Your second vid from inside the car sounds EXACTLY like mine does when starting in 1st gear.
dude i got like 900 miles on it and still happens
Since we both had it installed by knowledgable techs, and because both of our cars are shifting/driving fine, I think we can chalk this up to being a symptom of having aftermarket parts.
Some researching has found that the stock components, like the springs on the clutch, are tuned by the factory to cancel out any harmonic vibrations that can be audible. By replacing it with an aftermarket clutch, I think we threw that out of balance a bit.
I also found two other users who experienced the same thing as we are but they used ACT components. Apparently the noise does not go away for quite a while, at least for one guy, and it only went away after 5000 miles and few trips to the drag strip.
I can pretty much avoid the noise by either applying very little throttle, or a lot. We'll see how it goes after a few weeks.
I know this advice is too late for you, but I always replace the flywheel on a clutch job, especially considering how much abuse we put on those components with our cars.
You may have to have your idle rev raised to avoid the stalling.
For me, as of this morning the noise is starting to go away, I know it may come back but it seems to be lessening.
Now keep in mind that I replaced all components (clutch, cover, t/o bearing, flywheel) and as already mentioned in my previous post, put in fresh Mitsu Diaqueen 75W85 for the tranny. I also replaced the transfer case and rear differential with Mitsu LSD SAE 90 Gear Oil. I even did a fresh oil change and we had to put in new radiator fluid anyway. I wanted to make sure that the installers did as much as they could so that I had a fresh fluids since I'm at 30k miles and want this car to last.
So definitely put in fresh fluids for all of the drivetrain components and start breaking it in. I would still think about having your idle rev raised via an ecu flash because that may very well be the only solution for the stalling issue.
Hmm, if you car stalls then you may have other issues. How much wear was on the stock flywheel after you had it resurfaced?
There has never been an issue with the actual performance of this Competition Clutch/Flywheel, the engagement is nice and crisp, and I can launch much much better than with the factory setup. I also noticed some nice benefits of having a lighter flywheel.
So anyone looking for a reasonably priced clutch/flywheel setup, definitely take a hard look at Competition Clutch, because I won't hesitate to get the same parts once these wear out down the road.
I just installed CCI stage 4 with RRE 10.8 lbs clutch. I got about 6 miles on it right now and no noises. But the clutch pedal did get stuck in the "pushed in" position a couple hours ago. I put my foot under the clutch pedal and it popped up and is currently working.
