HELP oil light blinks n idle
Old Mar 17, 2009, 09:41 PM
Evokid03's Avatar
Alright guys well i just have a quick question.
Currently i bought an 05 evo 8 w/ 22k miles. The car itself runs great and is a blast to drive. Well since ive got it i noticed that when im in idle the oil light blinks. But when im driving the car it never comes on. THe light blinks on and off only in idle.
View video to see what i mean
Mods
Ams Uicp
Ams Licp
Ams Fuel Rail
Ams small battery
Megan 02
Megan dp
helix test pipe
Invidia N1 cbe
(**FP4R CAMS**)
arp head studs
Exedy Twin Disc
Turbo xs Dv
Tuned to 23psi
The car is on an unknow tune but im getting it retuned this saturday.
I just did an oil change to the car and shes running great.
Well just from thinking, could it be caused just because of the cam idle?
The car idles at 1k and holds that rev very well.
Should i be worried about it?
Plz let mek now what u think it could be thanks
Old Mar 17, 2009, 10:02 PM
abazaba410's Avatar
I have the same problem but it only startted happening since i installed cams and am untuned. I also have a tune sat. So oddd r it will fix it
Old Mar 17, 2009, 10:06 PM
SRT-TO-EVO's Avatar
Mine does it slightly (stays dim) when the fan kicks on.
Old Mar 17, 2009, 10:10 PM
Evokid03's Avatar
Ya so my guess its because of the cam
Idk some times it blinks alot and then sumtimes its very dim..
I just wanted to c if it was a major issue or not.
Im assuming its not
Old Apr 11, 2009, 10:44 AM
silver_evo's Avatar
If your idle is low/choppy then the oil pump will have a low discharge pressure. If your idle is ~950 and smooth and your getting the light, id bet that your bearings have excessive clearance and need to be replaced / and have your crank machined. But since you say you just got cams, i bet your idle is pretty rough.
Old Apr 11, 2009, 10:47 AM
justa4banger's Avatar
i have the same problem.... ive read tons of posts that its the oil pressure sending unit./....
Old Apr 23, 2009, 05:23 PM
Evokid03's Avatar
Oil light fixed
My new thread
https://www.evolutionm.net/forums/ev...d-problem.html
Evokid03
75
Jun 5, 2019 01:35 PM
Evokid03
Sep 9, 2010 11:52 AM
Evokid03
Oct 17, 2009 04:29 PM
Evokid03
May 28, 2009 05:30 AM
Evokid03
May 20, 2009 02:22 PM
Quick Reply: HELP oil light blinks n idle
