Can't boost past 10psi...wastegate and vacuum lines ok!!
#47
Guys, last night my car had problems boosting pass 10psi, it would aslo backfire. Today, I switched my spark plugs and it boosting at 21psi again.
Might not be the problem but easy enough to try first.
#50
Yeah, I'm having similar issues, I'm maxing out at 15/16psi sometimes 17 pounds. No audible leaks, but I suppose a boost leak test is in order, although I have been having similar, albeit less drastic, symptoms as Scarface2jz..... slight rattling in the exhaust and I did hear a slight pop 2-3 weeks ago prior to it dropping in psi.
But the thing is it spools up just fine and reaches ~15psi no problem, just levels off there though.
Honestly I hope it is the exhaust, it'll just give me another excuse to replace the stock unit lol...
Any recommendations on pressure testers?
delongedoug
46
Sep 7, 2011 04:04 PM
