no spark check list.. help!!
Old May 16, 2009, 09:01 AM
yellowevo82's Avatar
its not the battery, i stated that up top, i did check all the fuses, and i do not have an aem system its a apexi power fc..
nobody can answer this? im sure its not a hard question to most, im really starting to question this place for being supposedly loaded with knowledgeable people..
Old May 16, 2009, 09:17 AM
mattevo9's Avatar
did you do and coil pack testing with a dmm (digital muliti meter) could have an electrical problem.
Old May 16, 2009, 09:47 PM
evowner17's Avatar
It honestly could be any number of things. I checked alldata, and there are over 12 sensors that are involved with the ignition system. Any one of them could be at fault and causing a no spark issue. Are you located in carbondale, il? I might be down there sometime soon signing a lease for next year. I could possibly stop by and give you a hand, that is of course if we are speaking of the same carbondale haha.
Old May 16, 2009, 11:05 PM
can anybody get me a list of those 12 sensors?
Old May 18, 2009, 08:43 PM
Adam@MMS's Avatar
Has the engine ever run with the standalone? How hard would it be to put the stock ecu back? Just saying.
Old May 19, 2009, 11:00 AM
evowner17's Avatar
All this was found on alldata under inputs for ignition system:
-Atmospheric Pressure Sensor
-Camshaft position sensor
-Crankshaft position sensor
-Engine coolant temp sensor
-Fuel tank differential pressure sensor
-heated oxygen sensor
-Ignition switch
-knock sensor
-Manifold differential pressure sensor
-Throttle position sensor
-Vehicle speed sensor
-Volume airflow sensor
Not to mention you are running a standalone system, so it could be even more things. I would check to make sure that you have voltage at your ignition coils.
Old May 19, 2009, 11:52 AM
im getting abs no power to the relay on the left...
Old May 19, 2009, 03:40 PM
just having it towed, since im getting nothing out of this..
Old Jun 9, 2011, 12:36 PM
jonvr4's Avatar
sorry to bring back an old thread but did you ever figure this out im having the same issue right now with a customers car..
Old Oct 8, 2016, 08:33 PM
Paulevo9's Avatar
I'm getting this same issue now ! Has anyone find out what the problem is
Old Oct 9, 2016, 01:16 PM
Check the crank sensor... could be the trigger or sensor that wss my problem
terryaubuchon
Oct 27, 2017 07:29 PM
Jovan Caro
Mar 28, 2017 09:51 PM
VicVoss
Sep 28, 2016 06:37 PM
Awd_evo
14
May 26, 2016 01:33 PM
Evoguy!123
Apr 21, 2016 10:16 AM
Quick Reply: no spark check list.. help!!
