Not boosting past 21psi after O2 Dump installed
Old May 18, 2009, 07:16 PM
J8dailo's Avatar
ever since i got my o2 dump installed...i am not able to boost over 21psi...i have high pressure wastegate which is 21psi so it wont boost over wastegate pressure... im running greddy profec b II...was boosting 23psi before solid and now can't get past 21...check all hoses and connections and found one leak and fixed...still not boosting past 21psi and now i am lost...someone had simliar experience help me out?
Old May 18, 2009, 07:47 PM
sparky's Avatar
Stock turbo(VIII, or IX)? What WGA? Is it the FP unit?
Old May 18, 2009, 07:53 PM
evoracingstar's Avatar
i would just double check all the vaccum lines too man. from boost controler to the turbo all that stuff one of the hoses could of pop off
gl man hope u figure it out!
Evoryder's Avatar
what gasket did you use?
Old May 18, 2009, 07:59 PM
sparky's Avatar
BTW, which O2 dump did you go with?
Old May 18, 2009, 08:06 PM
dmoevo's Avatar
double check vacuum lines, might be pinched or something like that
Old May 18, 2009, 08:17 PM
Adam@MMS's Avatar
pull the wastegate line off and see if the boost starts to spike (let off the gas at 25 of course). This will help you narrow down the possibilities.
Old May 18, 2009, 08:54 PM
sspaladin28's Avatar
My o2 dump creeped like a ****. Funny that you are having the opposite issue
Old May 19, 2009, 10:11 AM
J8dailo's Avatar
I'm running the green ported and polished with buschur hp wastegate actuator..min boost is 21 psi for that actuator..I'm running map o2 dump...I checked all vaccum and lines..did found one leak and fixed..I thought I might have reverse the hook up at the control valve but its hooked up correctly...com to actuator and NO to turbo...I tried raising the set boost, start boost, gain ect higher but still boosted 21
Old May 28, 2009, 01:13 AM
J8dailo's Avatar
yep..i still can't tell why.... could it be my wastegate is stuck open? by if it is..it wouldn't make sense to hold 21psi solid
Old May 29, 2009, 09:39 AM
J8dailo's Avatar
got my wideband working...reading is all over the place... cruise is around 13.7-15.7... WOT is 10.1 afr...i need a tune bad
Old Jun 7, 2009, 05:44 PM
J8dailo's Avatar
finally got it fixed! i tested everything and was fine... turned out to be the connector between the boost control valve and the control unit was loose..which i wired it behind the dash...was pain in the *** to find..but now its boosting good!
Old Jun 7, 2009, 07:56 PM
ChrisCarey's Avatar
Glad to hear you got it sorted out, when can we expect a review of the o2 eliminator? ;-)
Old Jun 9, 2009, 08:00 AM
J8dailo's Avatar
i already did
Old Aug 23, 2009, 05:38 AM
stock_evoIX's Avatar
im having the same problem with an EPM dump
mine wont boost past 11 psi
Quick Reply: Not boosting past 21psi after O2 Dump installed
