Copper Spray on Headgasket - Yay or Nay
Old Sep 21, 2009, 05:23 PM
  #31
wevo1985's Avatar
ive used the spray on many of my talons and never had a problem. i didnt use it on my build of my evo and unfoutunatly its one of the 1st headgaskits i blew that only leaks under boost.
Old Sep 21, 2009, 09:00 PM
  #32
xRoguex's Avatar
Originally Posted by barneyb
Aluminum expands more than cast iron. So, the head is moving on the block every time the engine is run. I can imagine possible benefit from copper spray if running cast iron on cast iron or aluminum on aluminum but less so here.
this is a confusing statement. Let me -- unconfused others.
the point of spraying the individual sides of the MULTI layer metal gasket - is that that particular side adheres to the surface its mated to.
The multi layers - then allow the two to expand and shift at their own pace sliding on one another. While keeping those two surfaces - sealed to the head/block.
This is why you ONLY spray the two sides - NOTHING in the middle.
And this is why you do NOT spray a composite. This would cause the composite to not be able to shift/slide with the different expansion ratios - and it would inherently pull the hg apart.
Damian8MR
Aug 3, 2016 12:43 AM
gmac03
For Sale - Part Outs
11
Nov 23, 2015 11:47 AM
Noize
Jun 18, 2013 07:38 PM
chaotichoax
Jan 30, 2010 06:46 PM
Quick Reply: Copper Spray on Headgasket - Yay or Nay
