Mixing 92 and 100 octane
Old Oct 18, 2003, 04:06 AM
jomagi's Avatar
I only have access to 92 and 100 octane. Well, and crappy 93 that is 10% ethanol. Anyways, what is the ideal ratio of 92 and 100 I should use for daily driving?
Old Oct 18, 2003, 06:27 AM
jemm's Avatar
http://www.collectracecars.com/octcalc.htm
Aim for 94 - 95 pump octane.
Old Oct 18, 2003, 08:12 AM
ItsStockOfficer's Avatar
Basically, its just...The more the better. So there is really no point in even trying. You might as well stick with 92 and use pure 100 for race day.
Whats wrong with ethanol?
Old Oct 21, 2003, 07:05 AM
jbrennen's Avatar
Last Friday while I was at the track, I put about 2/3 of a tank of 100 octane in with my existing 1/3 of a tank of 94 octane, which should have given me a blended octane around 98. Then Monday night, after the low fuel light came on, I filled up with 93.
It made a believer out of me. The stock ECU can and will take advantage of octane levels well above the 94 octane that I usually run. I know this because I don't feel any substantial difference when I switch between 94 and 93, but felt a very immediately noticeable difference switching from 98 to 93. Going back to 93, the car felt underpowered and hesitant, sort of like it does after a cold start (but not as dramatic).
I am not sure how much of this was due to the ECU retraining. Perhaps it had retrained to the 98 octane, then it detected knock with the 93 octane and dropped back to a "safe" ignition map. But if that's true, that means that the ECU will advance ignition enough to make the engine ping on 93 octane gasoline, which indicates to me that the ECU is more adaptive than I'd been led to believe, and that putting race gas in the car (compared to 94 octane) is probably money well spent if you need the performance.
Old Oct 21, 2003, 07:17 AM
webguy330i's Avatar
jbrennen, I am in the process of conducting a similar ***-dyno test. Right now I'm blended at about 94.6 octane, but I will bump that up next time I fill up. I am doing it on a smaller scale from now on (1/2 tanks) to save a little R&D money.
The car definitely seems happier with the 94.6 octane I am running now. 'Course that's a rough estimate, I could be anywhere from 94-95 octane based on the amount of 93 that was already in the tank. The cold air we've had lately (~50-60 degrees) is really getting taken advantage of right now, such a difference from the weezing summer days of 80+ degrees.
Old Oct 21, 2003, 09:39 AM
Octane is valuable, believe it. Nevertheless, its a expensive and addicting drug. Your best bet is to make your car perform with what you have.
gallas
Jun 14, 2010 09:24 PM
XK120
May 17, 2007 08:29 AM
salukidude
West Region
15
Mar 11, 2005 04:19 AM
RKT SHP
Northwest Region
16
Dec 28, 2004 05:31 PM
BLKEVO8
12
May 1, 2003 08:57 AM
Quick Reply: Mixing 92 and 100 octane
