Busher's 3” downpipe fitment
Old Oct 28, 2009, 05:33 PM
18bora's Avatar
I bought a used Busher 3” downpipe that was supposed to my application. When I opened the box, I noticed that the flange didn’t have the beveled edge that mates to the doughnut gasket. From looking at it, it seems that it was either designed to fit without the doughnut or it’s for a completely different application. Can someone confirm either or? Thanks.
Old Oct 28, 2009, 05:38 PM
EvoM Moderator
scheides's Avatar
No donut.
Old Oct 28, 2009, 05:44 PM
Gary@MellonRacing's Avatar
from what i remeber the br dp , does not use the factory donut gasket , it uses a br gasket thats provided when u buy a br downpipe ,
btw , i should have one laying around id have to look
Old Oct 28, 2009, 05:45 PM
p.s get that white junk out of that pipe man ur goin to clogg the cat
Old Oct 28, 2009, 07:22 PM
BluEVOIX's Avatar
The buschur downpipes are not designed to use a donut style gasket. You can either use a round flat exhaust gasket or high temp copper rtv.
My friend is a tech for Ford/Mazda, when I had the Buschur downpipe he got a 2.5" round copper gasket that the mazda's used. I tried it out and it worked perfectly with no leaks. Its hard to tell from the picture below but its actually a crush style gasket.
Middle gasket:
Old Oct 28, 2009, 07:41 PM
CGMSTI's Avatar
It doesn't use any gasket. Take the donut off and install it. It seals just fine without those junky gaskets
Old Oct 28, 2009, 07:46 PM
Evoardo IX's Avatar
sorry to kind of hijack your thread but I have a somewhat related question: how about the hardware? i.e what bolts do we use when installing a BR DP? the oem spring kind?
Old Oct 28, 2009, 08:57 PM
charon2123's Avatar
Yep, just reuse the spring bolts.
Old Oct 28, 2009, 09:02 PM
BoostWhore's Avatar
I use to have one back in the day and mine leaked w no gasket.. thats the way its designed though
Old Oct 28, 2009, 11:10 PM
xRoguex's Avatar
My BR down pipe was installed with no gasket. It does not leak at all.
Old Oct 29, 2009, 10:59 AM
chaotichoax's Avatar
ditto
Old Dec 21, 2009, 06:09 AM
icrnk's Avatar
Did you try it with a gasket afterwards? Is this the kind that will work with it; http://www.lancershop.com/customer/p...productid=588?
So did you replace the buschur dp with another brand?
Old Dec 24, 2009, 10:13 AM
SaTa's Avatar
i had the same question as the op. thanks for all the replies.
however i noticed that the spring bolts and the donut allowed for the engine and exhaust to move. The br downpipe doesnt have a flex pipe on there. does this mean it is ok to have one solid fixture from the O2 housing all the way out back? or are we assuming that the rubber hangars are enough for the engine flex?
Old Dec 26, 2009, 10:58 AM
SaTa's Avatar
bump for any comments
Old Dec 26, 2009, 03:33 PM
BluEVOIX's Avatar
Go to Mazda dealership. Buy the RX8 gasket for the exhaust manifold to catalytic converter connection. Its the middle gasket from the picture I posted a couple posts above.
I used that gasket with my Buschur turbo back exhaust with ZERO leaks. I just got another bushcur trubo back and I will be using that gasket again.
Quick Reply: Busher's 3” downpipe fitment
