need diagram of stock map sensor pigtail
bought a 2005 evo 8 and there was no map sensor and pigtail was cut. I have a map sensor and pigtail but the wire colors are different. Was wondering if someone can post a pic or diagram of the wiring with colors of the wire and matching pins so i can re-wire mine.
Thanks
Thanks
Thanks for a quick response. In case it helps when you get a chance take a pic of your connector and i will see if the colors match
Thanks
Thanks
I tried searching through my service manual for a diagram for you but couldn't find anything. Mine is an 06 too so I don't know if theyd be the same even if there was something, sorry. They call it a volume air flow sensor in there, and I did a search of all the electrical and wiring diagram sections and nothing like a specific wire diagram for it. Good luck
Bringing this thread back from the dead to ask if the Yellow wire is the Signal wire to the ECU?
And if so is it the standard 0-5 vdc that the ECU usually uses?
Reason i ask is i was planing on putting the AEM map sensor from my Boost gauge and run the white analog 0-5 vdc output wire from the gauge back to the stock harness.
PS: Asked question a post later here as well
https://www.evolutionm.net/forums/ec...ml#post9333122
Athanasios
Athanasios
Athanasios
Athanasios
Yellow Wire - Manifold Differential Pressure Sensor - Pin #73
Black Wire - Sensor Ground - Pin #92
Grey Wire - Power +5volts - Pin #81
as to voltage this might help if you are still looking at this:
https://www.evolutionm.net/forums/ec...oost-help.html
evoxsi
Sep 29, 2014 01:07 PM
easarcher
Jun 12, 2014 07:15 PM
