Lifter tick only when warm??
Old Feb 19, 2010, 03:06 PM
millsyy17's Avatar
problem fixed. Had a bad cam, swapped out with different set of cams and ticking/tapping went away
so heres the story. I replaced my cams on my evo 8 with hks 272 and didnt bleed the lifters. Alot of good shops around been telling my bleeding lifters was an old saying and dont need to do it unless you have the lifters sitting around overnight while putting cams or ect.
the noise got quieter, i also did a fresh oil change. Now what happens is when i start it up on cold start its normal but after the motor gets to operating temp. it starts to tick???
Any help
Old Feb 19, 2010, 03:15 PM
wizzo 8's Avatar
I didnt bleed mine but mine is the opposite. Mine ticks when cold then goes away after a couple of min. Are you sure its not an exhaust leak?
Old Feb 19, 2010, 03:21 PM
millsyy17's Avatar
highly doubt it, sounds like its coming from the head, and i didnt have that noise till after i did the cam install
Old Feb 19, 2010, 04:27 PM
evo8htagreen's Avatar
With my Hks cams they ticked just a lil at all times after install. It slowly went away after 5 thousand miles or so
Old Feb 19, 2010, 04:32 PM
Kracka's Avatar
Bleed your lifters. I don't see why anyone would skip this step, it seriously only takes an extra 5 minutes to do all 16.
Old Feb 19, 2010, 05:09 PM
millsyy17's Avatar
could it be too late to bleed them now?
I dont undetstand if their hydrolic lifters why should you have to bleed them when they pump in/out oil when needed
Old Feb 19, 2010, 05:14 PM
I bled my lifters n it did nothing
Old Feb 19, 2010, 05:17 PM
millsyy17's Avatar
anybody think my CAS might be off 180*? would this cause some tap?
I tried searching but cant find any thread on how to adjust or set the CAS
Old Feb 21, 2010, 02:47 PM
millsyy17's Avatar
Update: I took all the lifters out and bled them and i still have that same tap??
Old Feb 21, 2010, 03:28 PM
05-EVO-GSR's Avatar
My lifters tick when the car warms up. Hopefully it will go away in the future.
Old Feb 22, 2010, 04:01 AM
millsyy17's Avatar
bump anymore advise?
Old Feb 22, 2010, 04:10 AM
tscompusa2's Avatar
I doubt car would even run with the cam sensor 180* off. but heres how its supposed to be:
Old Feb 22, 2010, 05:54 AM
dsmfan95's Avatar
I bled my lifters during my second cam install and there was no lifter tick. Could you be mistaking the injectors clicking for lifter tick?
Old Feb 22, 2010, 06:08 AM
gsrboi80's Avatar
Try the in car bleeding procedure they document in the FSM. Worked for me once years back.
The manuals procedure states to slowly ramp the throttle to 3k rpm, hold for 10 sec, lift throttle, then repeat.
Old Feb 22, 2010, 04:09 PM
millsyy17's Avatar
i know for a fact its not the injectors. Like i said i noticed the tap/tick noise only after I changed the cams
Whats the in car bleeding procedure? And whats the "FSM"
Quick Reply: Lifter tick only when warm??
