Wrong oil in transfer case
So keeping my frustration level at a minimum, I'll shorten this up.
My Evo 9 5-speed was towed into my local dealership because of transmission damage. Car was not under warranty so I had the dealership ship the T-case and Transmission to Jon over at TRE for a t-case tune-up and Stage 2 rebuild on the tranny.
The dealership got all the parts back and installed the transmission/ t-case. I drove the car off the lot and noticed a light humming noise after 30mph only when accelerating and while in neutral it whined it down. So I knew right away it had something to do with the T-case. Thought maybe it was normal after Jon at TRE did his tune up to it. Well i was wrong after talking to Jon and investigating what type of oil they put in the T-case at the dealership.
I brought the car back in and said I wanted to watch the Tech change my T-case oil. As I saw him add 75-85w oil to the T-case I immediately grabbed my DiaQueen LSD 90w out of my car and said "dude, why aren't you using this stuff!?!?" He said that's not what goes in there, so I said ok..... write me a receipt for what kind of oil you put in.
The dealership hasn't admitted that the wrong oil was put into the T-case yet, as per my conversation with the GM and service manager, even after showing them the receipt for the 75-85w and the spec in the Evo owners manual.
They're saying it would take hundreds of miles on the car before any "real" damage would take place on the T-case. They also said their national service rep agreed with them. I say bull**** and say "why the **** do they make special oils and spec sheets then...... so you can put the wrong oil in my T-case!?
So now my question is as follows:
How do I prove to these *******s that under extreme heat that the wrong oil (75-85w) can cause permanent damage.
Defiantly going to probably go to court, I just need some help proving my case. Any other ideas would be greatly appreciated as I contacted the DMV, BBB, Attorney General and contacted Mitsu HQ (which was no help I might add)
You don't really have a case because nothing was damaged. You can't sue because it might have caused damage. I wouldn't worry too much about it as long as you replaced the oil asap. Awhile back when I was more ignorant, I drove on bulk non-oem fluid in my TC for 2,000 miles before I changed it to diaqueen. Now, currently at 62,000 miles and going (daily driver). Keep in mind, I have the oh-so-fragile 03' model as well. Bottom line, relax and just be glad you caught it early.
Thanks. I was planning on changing to DiaQueen LSD this week sometime but the general consensus from what I'm hearing, esp from Jon at TRE , is that the tcase will fail in short order.
Maybe to put it into perspective the wrong oil will probably do damage very soon. I toasted a transfer case (back in 2003) from putting Redline 75w90 in the tc and driving from Seattle - Portland - Seattle. When I got home it was toast. Got replaced under warranty (towed car to dealer Mon morning).
Been there and done that! I had a shop put the wrong oil in my t-case and I had to take legal action. I personally drained the fluid and took it to a lab and had it tested. When it came back the wrong weight and additive package, I sued and won the case! I took months but I won. Keep in mind, you must have ALL your ducks in a row.
If you have further questions, PM me and I will go into more detail.
I am going through the same debacle right now. I dont think anything will come of it - I have been given the runaround by every possible person at both the dealer and at customer relations. I am not a happy camper whatsoever.
b
b
That's interesting. I spoke to the owner of the dealership and he spoke to his lead service coordinator which called me yesterday and said the wrong oil could cause a severe issue but to change the fluids out anyways and go from there. He also agreed with me that the wrong oil in the T-case will cause damage immediately. Finally someone with mechanical experience that actually works at the dealership
Well I think persistence will pay off in the long run but will be a long haul.
Thanks dambikeracer for the help and insight.
So the mitsu dealership didn't completely admit guilt and they're using the argument of how the wrong fluid wouldn't cause much damage until xxx miles but they're giving me a brand new T-case anyways. haha
doncarbone
Apr 21, 2020 01:15 PM
Icegod87
Oct 21, 2014 11:15 PM
