Drivetrain problem
Drivetrain problem
k guys the time has come and looks like my transfer and axles are gone, ...... it started with a low knocking in my 2 front wheels and first I though they are the coilovers since I got the megans and they always loosen from the top. now a month later the knocking becomes louder and really annoying, so I decide to take it to my friends shop since he was a mechanic at a mitsu dealer.
Well today he let me know my axles are "gone" so its my transfer. I told him if its that possible about the transfer been "gone". Since it drives fine, the only problem is the knocking .......... could it be possible to drive around with a broken T-case?
I would like a second opinion from you guys, There has to be someone out there that had experience this problem and what do u guys recommend? pls help
the knocking can be heard when you are taking off .... when you come to a stop, and when you do a full turn on the steering wheel (both sides )
Your help + opinions is very appreciated.. thank you
thanks, about the t-case I dont think that would be a problem too right?
I mean can u even roll with a broken t-case? the only sound that im getting is knocking ...
knocking is not a TC sound usually, its whining at speed. I have "knocking" from my front end sometimes but its the stabilizer links, they pop and bang when they go bad. Might want to check so more suspension components before you drop an *** load of money on axles and a TC.
thanks so much guys, that what I wanted a second opinion.... it was too much for my TC to be out! i barely have 27k miles and im not a big launch or race fanatic im more just a cruise guy.
ok so the stabalizers that u say..... r does the one from the front sway bar??
yes the rubber stabilizer link ends get warn and when they do they make popping sounds. Also might want to check out this thread...https://www.evolutionm.net/forums/ev...end-noise.html
roblee8908
Nov 3, 2013 08:44 PM
neonglh
Jun 28, 2009 11:27 AM
