my diy K20/24 series honda cop non cdi
That's awesome. I've been pondering this the last couple days. Would you mind drawing up a diagram and maybe a how to? This would be a great helping hand for the Evo community! Good job.
i'm glad someone has copied me
honda boys use these up to 900hp, that why i did them.
mitsi wiring diagram for coils
honda wiring diagram for coils
i'm sure you can work out what goes where
and if you can't -
Honda
Power - black/white = 12v
earth - black
signal - multicoloured wires
Mitsi
power - black/white = 12v
earth - black
signal - black/yellow(1+4) black/green(2+3)
Cheers, Mike
and if you can't -
Honda
earth - black
Mitsi
earth - black
Cheers, Mike
Good to hear!
yeah that 2nd pic will work, just make sure the wiring gauge is large enough to flow twice the current (before it tee's off).
i'm not actually sure what 2 or 4 coils would require to run, i ran all my wires as 16gauge, total overkill
ALSO!! did you reuse the stock capacitor or did you install another one?
well i went out and messed with the spark plug gap previously with the okadas i was only able to get it around .20-.22 and went out and set them at .30 with no misfires same plugs no new ones and they are bpr8es will try to go larger soon just need to get some 1/4 inch thick carbon fiber and high temp loom
