Best spark plugs
http://www.lancershop.com/customer/p...?productid=718
I run these in my car now.
Some people and tuners like to change plugs every 3,000. Like I said you could run the iridium 8's for like 60k. But if you are racing with it, maybe you would want to change plugs more often?
thanks for the good info! i might try those plugs out for my ix
do you know the part number for those plugs for a ix
or
http://www.lancershop.com/customer/p...&cat=89&page=1
the colder step is expensive, but at least they shold last a long time
As long as your plug is a B - stands for the diameter, 8 - stands for the heat range, and the E - stands for the length. the R stands for resistor, the P is for projected, and the S stands for steel. The only numbers that matter are the B,8, and E. If you have those then your plug is the same.
