Cams
Good idea for using a spring retainer kit cause like a idiot I used the gsc2 cams on stock springs with a 6262 turbo on 31 psi and I'm having valve flutter ,valve float ,and cannot run past 7,000 rpms only on 8 * due to the valve noise..As far as the kit you want to run invest in $125 more and go with the supertech kit part #sprkm-100-7d one of the best kits that's proven.
FS[SouthEast]: Mivec Cam Gear
hutch959
10
Nov 25, 2016 05:35 PM
