Best spark plug and wires for Evo 8
Old Feb 3, 2011, 04:46 AM
BEISSEN's Avatar
Originally Posted by My03evo
Well, I got the car and tonight on a pull it misfired twice plus it's time to change the plugs since I don't know what the hell's in there. From what I'm searching I should be going with the BPR8ES or BR8ES...Debating on which one to go with.
Where are you getting yours for $6 for all 4?
Anymore comments on if I should go with the projected tip plug (BPR8ES) or non?
Im running NGK BR8ES plugs gapped at .23 also I have the sparktech non-CDI unit and I have yet to have issues also I go about 2-3 oil changes now with the better spark.
Old Feb 3, 2011, 08:53 AM
Davo's Avatar
When needing wires I bought some Denso's off Amazon and they fit perfect and also worked great. Not a bad option.
Old Feb 3, 2011, 09:03 AM
gsrboi80's Avatar
I run BR8ES at .026 here and 130k mile coils. Wires and boots replaced once just as a pm sort of thing.
Never once have I had a misfire in my car even out to 30psi on a 61mm
Old Feb 3, 2011, 09:26 AM
JohnBradley's Avatar
Stock wires work the best short of a Sparktech system. Magnacore might be hotter but dont last as long.
Old Feb 3, 2011, 12:04 PM
browningderek's Avatar
^^ yea! i let mine sit for a year and they went bad. junk!
Old Feb 4, 2011, 08:03 AM
My03evo's Avatar
So looks like people are going with the BR8ES rather than the BPR8ES...since theyre a hair colder I guess it can't hurt on my setup?
Old Feb 4, 2011, 09:30 AM
LookThatsMe's Avatar
well me i bought my evo with 26k on it and it had NGK plugs in it so i figured ill change them. i went to a performance shop and they sold me Denso IK31#4 and the car ran great and then sat home for a week when i was on vacation came back and couldnt drive the car it was misfiring on all 4 cylinders, i went back to the shop and they gave me a set NGK R5671A-8 and the car runs perfect
Old Feb 7, 2011, 04:57 PM
My03evo's Avatar
Picked up some of the BPR8ES plugs from Advance for like $2.25 a piece, changed em in the parkin lot and found out the previous shop put in BPR9ES's. I had a missing problem so I figured it was the plugs since I didn't know what was in them or the history of them so put in the 8's and still missed under load/boost. Did it for a day or two but since last night it has been FINE and completely back to normal so I have no idea what's going on, If I got on it hard once boost and load got up there it would miss like someone turned the key off, not sure if it is fuel or spark related, there would be no CEL after it so I'm assuming fuel?
Old Feb 7, 2011, 05:47 PM
Rex915's Avatar
I got some magnacor 8.5 wires for sale almost brand new for cheap. lmk what you think, thanks
Old Feb 7, 2011, 05:58 PM
casper980's Avatar
I have had my magnacore's for almost 8yrs...Chris Black did tell me there was some fitment issues and stock were better. Then I heard magnacore redesigned the seats...its whatever though I am going to COP. Chris changed out my NKG iridium for copper version to rid my car of the misfire. The first time something got cheaper for my car, at less then $10 a set. Long story short Copper plugs, stock wires until COP.
Old Feb 7, 2011, 07:32 PM
My03evo's Avatar
I don't think my problem is the wires because everything, motor/trans/clutch has less than 5k on everything so would only want them if it was CHEAP.
Pm me a price if you want
Old Feb 7, 2011, 07:39 PM
Rex915's Avatar
pm'd
Old May 6, 2014, 05:41 AM
cdone's Avatar
O'Reilly s
QUOTE=My03evo;9044104]Well, I got the car and tonight on a pull it misfired twice plus it's time to change the plugs since I don't know what the hell's in there. From what I'm searching I should be going with the BPR8ES or BR8ES...Debating on which one to go with.
Anymore comments on if I should go with the projected tip plug (BPR8ES) or non?[/QUOTE]
Old May 6, 2014, 07:02 AM
gsrboi80's Avatar
I get 4 BR8ES for ~10 bucks at Advanced or Autozone
My car 100% prefers the non-protruded tip plugs over the protruded tips both in the 7 heat range I use to run and the 8 heat range I run now. Smoother idle, accel, and look very uniform on replacement
Changed every 3-5k
Old May 6, 2014, 07:15 AM
e_kobz's Avatar
I have the SpoolinUp COP and have no complaints what so ever. Quality part, works well, looks amazing, and is priced right.
gregivq
Lancer Engine Tech
43
Dec 2, 2018 09:23 AM
joberk3
Aug 10, 2014 09:41 AM
crispeed
AWD Motorsports - Florida
25
Sep 18, 2013 08:24 PM
5LEEPERISAH23I
15
Sep 13, 2010 03:33 PM
N.sane
Lancer Engine Tech
11
Dec 16, 2009 08:48 PM
Quick Reply: Best spark plug and wires for Evo 8
