New BW EFR Turbo Thread
#4367
True, I already have the cast iron 8374 and was going to go with a 9174 super core with aluminum center to save some weight and add some power; but I think I can wait for the 8474 as I think it will fit my needs better.
#4369
but then i meet showtime Ken Thwaits. At SEMA booth. Does any body know this evo 9 with fullrace efr 7163 IWG. he gets 2nd place optimal street car competition series on the week end
#4372
Just pulled the trigger on my CBRD 7163 kit. Will be paired with:
2012 GSR
ID1000cc
GSC Stage 1 cam
AGP 3.5" intercooler
ETS LICP and UICP
ETS Intake w/ 3.5" MAF adaptor
Perrin exhaust
Grimmspeed EBC
Radium surge tank w/ AEM 320lph
Hoping for good numbers... Will update in late Jan or Feb when it gets tuned at RRE.
Anyone on here have insider knowledge on when the 7163s are arriving stateside?
2012 GSR
ID1000cc
GSC Stage 1 cam
ETS LICP and UICP
Perrin exhaust
Grimmspeed EBC
#4373
2012 GSR
ID1000cc
GSC Stage 1 cam
ETS LICP and UICP
Perrin exhaust
Grimmspeed EBC
2012 GSR
ID1000cc
GSC Stage 1 cam
ETS LICP and UICP
Perrin exhaust
Grimmspeed EBC
K-Rimes (Dec 21, 2016)
#4374
Some more 8374 IWG results.
9.3CR 2.0LR
Ported head, 1mm valves
8374 T4 0.92 IWG
3.5inch dump/front, 3inch straight pipe back
Hypertune cooler
Link ECU
Still a bit of room in shaft speed, but rear housing back pressure is getting out of control.
Still an epic powerband, making 37psi by ~4150rpm, still pulling clean past 8k.
This Mainline dyno reads bang on 15% lower than Dynojet figures.
388whp on 92 octane at ~23psi (446whp Dynojet)
589whp on E70+ at ~36psi (678whp Dynojet)
Hows this compare to other results on these as I haven't seen many IWG 8374 results in the past.
9.3CR 2.0LR
8374 T4 0.92 IWG
Hypertune cooler
Link ECU
#4377
Hi Benja,
Thanks for your dyno results. I haven't seen any 8374 IWG results on Evo.
Are the numbers WHP or at flywheel? And what fuel is it running?
Could you tell, how much back pressure there was vs boost in the highest hp run?
#4379
Benja thank you for sharing this
I concur, this is only 1,58 bar... My option would be turbo speed sensor and 2 bar But each to their own, and this is still a great project
On your project with 2.3 engine, or someone else's with 2.4 this is going to be a killer
#4380
EFR knowers, how do IWG EFRs perform vs. EWGs? There is obviously a difference between dumped and re-routed wastegate setups, just wondering if IWG vs EWG makes a difference, too. The B2 frame has a 42mm wastegate, which is plenty big, but perhaps it creates extra backpressure that kills power?
Anyway, stumbled across this: http://www.8thcivic.com/forums/vittu...s-buy-iwg.html
I don't understand how a larger A/R housing with external gate can outspool the IWG housing, but I'm not placing too much faith in that "test".
I have a IWG 7670 and I'm starting to think it may be a bit underwhelming on a 2.0L.
