engine still ticking after lifter change
Hey alll,,,
mmm im having a lifter tick ( i think ) on my evo 8 for a couple of week now...
the car on idle is running normal, no tick, when i just rev the car 2000-3000 it will start ticking... evn if im driven,,, on idel no tick.
i changed them to GSC Zero tick from VIVIDRACING ( my perfect stor ever ), and NO CHANGE at all for the ticking noise
some ssaid that its rod bearing,, which i dont think so...bearing sound it diffrn
can any1 help me with that!!!!!!! neeed help plese
I'm in the same boat. After my recent revolver cam install and new springs/retainers, it only ticks when the car has load on it (in gear), in about the same RPM range. Seems to only make the ticking sound when it's completely warm and/or warm outside (65+ degree outside temps).
My 90 Talon Tsi Awd had the lifter tick and I installed the "revised lifters" with the bigger oil hole and they still tick. It was not until I poured in a very small amount of Lucas Oil Stabilizer did they stop.
Doesn't sound like lifters to me. Lifters tend to tick more when cold and at idle. Revving usually makes it go away, not cause it to happen. My old lancer would tick loudly when cold but the tick would fade when it got warmer and would usually go away if I revved past 3500 rpm.
It's often caused by a dirty bit of oil getting stuck in the lifter, and warming/revving helps push it through.
Ive changed the lifter and the oil n the same time.
Cold or warm its still the same
Withload or with out same sound
The only upnormal im gettting is when i boost the car up. The AFR gos rich 10.0 straight
yea op seriously post a video of it, otherwise how are we supposed to help you honestly? theres very few things that can cause ticking noise....??? could be lifters which u replace? could be a belt tensioner starting to go bad? could be an exhaust leak?? instead of whinin help make our job easier to help you and post a video, otherwise this is useless nonsense.
soorry gys for not adding the vedio,,,,
http://www.youtube.com/watch?v=h4hy6Oi6S64
click on the link and hear the noise coming from the engine when i rev the car,,, 2000-3000 RPM
