AMSoil 75W-140
AMSoil 75W-140
Just had a few questions for anybody that was running this oil in the transfer case...
1) Why would you run this in your transfer case over the 75W-90 oil (stock transfer case)? What benefits and what downsides are there to running this thicker oil
2) Can you mix the 75W-140 and 75W-90 half and half?
I already asked someone and couldn't get a straight answer on it...
Thanks
Thanks
in the transfercase and rear i have been just using oem and its fine.. for transmission though i run 75w90 severe gear and it seems to help in really cold days the transmission doesnt freeze up ever.
i didnt see many actually using that amsoil severe gear lube in the trans and im curious why not? it seems to work well. i have about 12k on my shep trans with it so far.
I run Redline 80w140. Jon at TRE said to run that weight. I have used Redline for many years. I like it better then OEM cause it is synthetic so it won't break down as easy. Very important when you are running not much more then a half a quart in the rear and tcase.
Yeah, there are a few folks running SVG in the trans, i have al few customers running 140 in the trans but with rediculouse torque and running tripple carbon exedy
You're saying 140 is more protection so why is everybody still buying 90?
1. If you are running TQ above 450 and a heavy clutch spcially tilton or exedy tripple where the TC and rear diff see a high load and you are launching the car or racing it this is where 110 or 140 is and could be benneficial as thicker oil acts as a shock absorber between the gear and the ring assy or the LSD worm gears
2. Keep in mind most high quality oils today have a high shear load rating, for example the SVG 75W90 usto be rated at around 2500 lbf before it sheared down, a year ago this oil was redesigned to handle >3500 lbf this number is very competitive
3. Do you need a thick oil to ensure proper lubrication is there, NO you dont this is not the 60's 70's or 80's todays synthetics specially the Group 4 and 5 oils have the ability to hold up to extreme loads allowing you to run thinner oils, tolerances during design have been getting smaller therfore allowing for running thinner oils,,, but has the Chemist Engineers been able to formulate thin oils that can handle the extreme pressures YES is the answer,,, this is why you see cars running 0W20 oil and running it for 10,000 miles
My goal here is help you understand where and when to use 140 or 90
Wulfen (Jul 11, 2022)
kyoo
92
Feb 25, 2019 07:16 AM
dambikeracer
88
Feb 24, 2011 06:11 AM
Nex1
Toronto Lancer Club
Jun 3, 2010 10:10 AM
