Gearbox/Transfer Case Oil Change
Hi guys,
I'm doing a clutch install and I have OEM Mitsu fluids for gearbox as well as transfer case to put in also. I have found a method for changing the transmission fluid that I think I will be using:
However, I have the JDM Evo VIII which has the AYC. Does AYC have seperate fluid somewhere that has to be changed also? And what fluid should be used? I can hardly find anything about the AYC on Evo VIIIs.... So any help would be appreciated!!
This method can be used while the transfer case fluid is being changed. This is the messiest way, but is does ensure that the transfer case is full.(May require a helper)
-After draining the transfer case, use a hand transfer pump and insert the hose from the end of the pump into the transfer case drain hole.
-Tightly wrap a rag around the hose to make a seal.
-Continue holding the hose while pumping 1qt into the transfer case.
-Quickly remove the hose and reinstall the drain plug.
-Now you can remove the FILL plug, letting the excess fluid run out through the fill hole. Filling from the bottom ensures the transfer case is full.
The ACD and AYC use the same fluid from the same pump since you have a JDM 8. You should not have to change them. The reservoir should be located at the rear of your car on the drivers side.
The transmission fluid and fluid in the transfer case you can replace with OEM fluids when you swap the clutch.
EvoM Community Team
We don't have the AYC in the US but a quick search here reveals:
https://www.evolutionm.net/forums/ev...ese-specs.html
MurderInc
Evo X How Tos / Installations
20
Dec 16, 2022 12:05 PM
chaotichoax
32
Feb 11, 2020 09:00 PM
runny_yolk
Apr 12, 2004 08:09 PM
2003, 2006, case, chang, change, chenge, evo, evolutionm, fluid, mitsubishi, oil, tcase, transfer, transfercase, transmission, xmr
