View Poll Results: Clicking noise when you press down on the clutch.
I have the clicking noise
14
56.00%
I do not have the clicking noise
11
44.00%
Voters: 25. You may not vote on this poll
If you are talking about a clicking noise when the clutch is to the floor then, yes, it is normal. It's the pedal hitting the microswitch that has to be depressed when you start the car (try starting the car with the clutch up, it won't). If not, then no it's not normal.
I have a clicking noise. When you press on the pedal, you can hear it and happens again when you let off the pedal right? I took mine to the dealer and he told me that my clutch and throwout bearing had to be replaced. It only happens when the car is warmed up.
Re: Clicking noise when you press down on the clutch.
Originally posted by CarPhoto.net
There is a clicking noise when you press down on the clutch.
Is this normal?
Is this bad?
Is this normal?
Is this bad?
Throw out bearing?
Im worried is this normal?
It is probably the clutch start switch as stated above. Tell us when you hear the noise, is it when the pedal is at or on the floor.
If so it is completely normal.
There is no evidence of any crankwalk issues on the Evo engine so far and I doubt Mitsu would not have learned thier lesson.
Most definatly the throw out bearing
I've been in an evo when it went out.
And not the bash your drivin the evo is not a drag car you must must must wait 1/4 of a second before shifting into second gear
This click noise occurs when the car has been started in neutral at a standstill in my driveway. Not when I am driving.
At a stand still I get a click noise when I press down the clutch.
Originally posted by nebolic
normal, i have that sound too
I've heard purposely making larger tolerence so the clutch fails rather than your trans?
For your infomation before mine when bad the clutch pedal started to vibrate. So no virbration on clutch pedal during depressing, no worries i guess.
