Cam identification question
Old Apr 25, 2012, 01:03 PM
TopLevelPerformance's Avatar
Cam says ES 4604, sounds familiar to anybody?
Old Apr 25, 2012, 01:08 PM
okevolutionVIII's Avatar
I swear I saw that same ES 4604 stamp as well as the top stamp on the 2nd pic on my Revolvers last night when I was swapping them back in. I might double check tonight if this isn't figured out by then.
Old Apr 25, 2012, 01:27 PM
meckert's Avatar
a yahoo seach would be better-- from what I gather the es6404 is a core stamp that a number of vendors use--they then grind to spec- crower and comp cams were mentioned as using them. If this helps.
Old Apr 25, 2012, 01:37 PM
Thanks guys keep them coming, i will do the yahoo check n yea let me know if these are Revolvers if u can thanks man
Old Apr 25, 2012, 01:52 PM
Blue91lx's Avatar
ok's point is that you can't tell if they're Revolvers by the stamp, as the stamp is used on the cam cores, which are then distributed to tons of different vendors.
Originally Posted by GrocMax
'ES4604' is a core supplier here in the US, could be anyone who uses that core supplier. There should be other numbers etched or stamped somewhere, should be real obvious.
Old Apr 25, 2012, 02:30 PM
Second pic theres 2 symbols, V on the bottom n cant tell what that other symbol is. Hopefully someone recognizes them, cuase those the only numbers i see
TopLevelPerformance
Jan 16, 2013 09:58 AM
TopLevelPerformance
47
Mar 20, 2012 01:51 PM
TopLevelPerformance
For Sale - Cars For Sale
Jun 22, 2011 09:36 AM
Gavin@TopLevelPerformance
Jun 6, 2009 03:58 PM
TopLevelPerformance
Oct 31, 2008 10:23 AM
Quick Reply: Cam identification question
