Rebuilt my ACD Pump
Old Apr 30, 2012, 07:29 PM
Davedangerous's Avatar
Thumbs up Rebuilt my ACD Pump
Well after dealing with the ACD lights coming on/off for the past 30k miles (mostly on hot days) I finally fixed the problem. I've been browsing the forum and finding many members encountering the same issue, but with the only solution being a replacement from Mitsubishi...until now.
A fellow evoM member in Croatia developed a rebuild kit that is sold by acd tuning here in the sates. So I figured the pump is shot, what the hell...why not!
It took about 2 days because I was having some issues disassembling the unit but I contacted kikiturbo (creator of the kit) and he was very helpful in solving my problems.
So here's what I was dealing with;
Motor removed from the unit
Severe corrosion along the bolts so I had do some extra cutting
All 3 pieces
So following kikiturbo's instructions from his video I began to clean the pump and begin the rebuild. Using a sharp chisel, some dremel sanding wheels and brake cleaner I was able to bring the pump back to life.
After reassembling the pump and testing to see if it worked I cleaned and painted the pump body. I then used some silicone for metal surfaces to seal all the seams.
Next step was to reinstall the pump, bleed the ACD and go for a test drive. Test drive went well NO LIGHTS
I will keep you guys updated as the weather gets hotter if the lights do come back. But after hearing the pump spin at a low rpm and build 10bar of pressure, I'm pretty confident that the problem is solved.
Old Apr 30, 2012, 07:30 PM
here are the how to videos for anyone who hasn't seen them;
http://youtu.be/ZrYjQat4KGE
http://youtu.be/czXwPhJ6XkQ
Old Apr 30, 2012, 08:40 PM
GetPowerHouse's Avatar
WOW, very nice!!q
Old Apr 30, 2012, 10:24 PM
Thore's Avatar
Woot! I will be bookmarking this for sure!
Old May 1, 2012, 03:57 AM
njboy's Avatar
Davedangerous,
Do you drive your car during the Winter? Just wondering if road salt made your corrosion worse. I've wondered with where that pump is located that it gets slammed with lots of water and salt spray.
Old May 1, 2012, 05:15 AM
kikiturbo's Avatar
on US cars it is not so bad because it is in front, on others it is in the back, right next to the back wheel..
Dave, that is one severely corroded pump.. I haven't seen it so bad.. (ok I have but that is on a evo X.. )
Glad you made it ok.
best regards
vlado
Old May 1, 2012, 05:29 AM
finalflash_17's Avatar
Awesome!!!
Old May 1, 2012, 07:16 AM
mostarac13's Avatar
how much for the rebuild kit?
Old May 1, 2012, 07:17 AM
mostarac13's Avatar
it looks like a PITA to do
Old May 1, 2012, 07:19 AM
Originally Posted by njboy
Davedangerous,
I do drive my car in the winter. New England winters and road salt definitely did it's damage (6 years & 92,000 miles)
best regards
vlado
Thanks again for the help!
Old May 1, 2012, 07:39 AM
blowngasket's Avatar
how much and where can i get this kit?
Old May 1, 2012, 08:02 AM
I did lose my patience a couple of times But then I'd stop have a beer and think it over and then when I calmed down I'd work on it again.
parts were 200, tool kit was another 200. You don't necessarily need the tool kit but it makes tasting and bleeding the pump a whole lot easier. http://acd-tuning.com
Old May 1, 2012, 08:39 AM
gpfury86's Avatar
http://www.acd-tuning.com/
Old May 1, 2012, 02:04 PM
mostarac13's Avatar
Thank you bro
Old May 1, 2012, 05:08 PM
lan_evo_mr9's Avatar
Would you say that the cost of the service from ACD-Tuning is fair after going through it yourself? Good job by the way
Quick Reply: Rebuilt my ACD Pump
