low compression in three cylinders
Old May 6, 2012, 07:26 AM
vinnieg's Avatar
I did a compression test and found 125psi, 145psi, 135psi, 165psi
im thinking its my valves or valve guides are worn, what do you guys think it could be ?
Old May 6, 2012, 09:04 AM
Thore's Avatar
Go to a shop and have them do a leakdown test. That will give you a better idea whats up.
Old May 6, 2012, 09:07 AM
BoostINurI's Avatar
Stock block? How many miles?
Old May 6, 2012, 09:52 AM
Chef-j's Avatar
You have a stock cams?
Old May 6, 2012, 10:54 AM
Anarchy99's Avatar
Sounds like your testing method is off
Old May 7, 2012, 11:03 AM
vinnieg's Avatar
stock block with stock internals no cams my cars at the shop thats where we found low compression
Old May 7, 2012, 11:09 AM
SmurfZilla's Avatar
Did they do a leakdown?
Old May 7, 2012, 11:24 AM
Initial_r90's Avatar
+ 1 leakdown
Old May 7, 2012, 11:27 AM
escodotcarter's Avatar
id say that still pretty good compression. Probably just some dirty valves.
Old May 7, 2012, 03:44 PM
Redline-Z's Avatar
125 and 135 are below 10% and need to be addressed.
Old May 7, 2012, 03:53 PM
meckert's Avatar
If the car is running well, let it be---thinking you are trying to fix a problem that doesnt exist...so you are high on one cylinder--doesnt mean you are low on 3. if the numbers were 110 or less then maybe...but really? Look at the one that was 165 one more time and see if you get a different reading. The 3rd cylinder is the one to watch that tends to go before the others.
Old May 7, 2012, 04:47 PM
vinnieg's Avatar
im waiting to hear the results from the leak down i asked to have it done on thursday im still waiting and i did the compression check 3 times cylinder 1 2 3 are low 4 is at 165 spec is 175
Old May 7, 2012, 04:49 PM
true but personally I wouldn't go and tear apart the motor for that.
Old May 7, 2012, 04:51 PM
vinnieg's Avatar
i dont run at 90% thats how problems occur if there is an issue you fix it its called preventative maintenance
Old May 7, 2012, 05:10 PM
vinnieg's Avatar
i found this in the service manual
"Standard value (at engine speed of 250 r/min): 1,000 kPa (145 psi)
Minimum limit (at engine speed of 250 r/min): 637 kPa (92 psi)"
with that spec is my motor fine and has high compression in cylinder 4? now im confused!
Quick Reply: low compression in three cylinders
